stepper config / paralell port gecko 203v
27 Oct 2009 15:27 #1047
by drstein99
stepper config / paralell port gecko 203v was created by drstein99
I retrofitted my Bridgeport Boss cnc, fitted with geck 203v's, 24v power, 2 paralell port cards, and linux emc2 (downloaded the recent iso). it jogged all three axis good at first for like 20 minutes I was playing. now every now and then, one axis will get stuck and NOT reverse. or another axis wont step. I reboot the machine, power every thing down turn back on and it might work or not work.
I used stepper config wizard, selected gecko 203v. Other then the wiring, I cant imagine anything else going wrong here except a config setting or timing issue maybe. I know in mach-3 I can set the ms debounce on the direction pin, which sometimes effects the steppers, but that seemed to be covered when I selected "203v" in the stepper config wizard.
Any advice?
Any advice?
27 Oct 2009 23:32 #1048
by BigJohnT
Replied by BigJohnT on topic Re:stepper config / paralell port gecko 203v
Did you run the latency test for an extended period of time like overnight? Do you ever get an error about latency?
I'm running 203v's on my plasma. I used to use the parallel port but for other reasons now I use a Mesa 5i20. The default settings should be correct.
It sounds like your acceleration is too high... reduce that and run this test.
www.linuxcnc.org/docview/html//common_St...iagnostics.html#r1_3
28 Oct 2009 02:13 #1054
by drstein99
Replied by drstein99 on topic Re:stepper config / paralell port gecko 203v
I did not run it overnight., I will try these debugging procedures - thank you. I checked my wiring using a logic probe, and the signals are signaling (though I cant check steps, I just check direction pins). I used very thin gauge wires, and they kind of jump around inside the cabinet. After I rigged up new wires, it appears to work - though I couldn't rigorously test like I did the other day.
Time to create page: 0.076 seconds
