E-Stop Warning Light - how do i connect???
- deltagirl
- Topic Author
- Visitor
26 Nov 2009 05:16 - 28 Nov 2009 13:39 #1201
by deltagirl
E-Stop Warning Light - how do i connect??? was created by deltagirl
i want to make a light turn on when the e-stop button is pressed or when the e-stop, via software, is pressed.
I have EMC2 (2.3.4)
I have a 6Vdc Relay (6Vdc - 1A/125VAC)
I have a 12Vdc 200mA MAX light
I have a separate 12Vdc 3A source for the light
pin 13 - GND
= 5Vdc / 1A ( e-stop working 100%, just a on/off switch, believe the 1K resistor in front of pin is a pull up to make it give steady 5Vdc)
pin 1, 8, 9 - GND
= 3.3Vdc / 1A (i think i need those pull up resistors to make it 5 volts, not sure what to do)
QUESTION:
When E-Stop pressed (either hardware/software)it makes input go high, how do i make an output (eg: pin1) go high so i can put a relay in to turn on light
TRIED:
setting output pin1 to "E-Stop Output"..... didn't seem to work, tried variations of inverted for in and outputs.... nothing
ok any help would be grateful
I have EMC2 (2.3.4)
pin 13 - GND
pin 1, 8, 9 - GND
QUESTION:
TRIED:
Last edit: 28 Nov 2009 13:39 by deltagirl.
02 Dec 2009 03:47 #1225
by BMG
Replied by BMG on topic Re:E-Stop Warning Light - how do i connect???
www.linuxcnc.org/component/option,com_mo...rc/Itemid,8/lang,en/
Drop into the IRC Chat (Java client link above) and check with other EMC power users there on how to set this up.
They should get you going pretty quickly.
- ldmarsaglia
07 Dec 2009 04:21 #1266
by ldmarsaglia
Replied by ldmarsaglia on topic Re:E-Stop Warning Light - how do i connect???
Hello,
I think you can use halui to do this, there are three pins in halui for the E-stop, and one of those pins is a hal output pin that tells the state of the E-stop button.
You only need to link this pin to a pin in your hardware driver (parport, mesa board)
Here is the information.
www.linuxcnc.org/docview/html//gui_halui.html
I hope i could help you.
Best regards.
Leonardo.
Best regards.
Leonardo.
07 Dec 2009 06:34 #1267
Replied by cmorley on topic Re:E-Stop Warning Light - how do i connect???
Setting output pin1 to "E-Stop Output" should work. (I assume your using stepconf) I checked the hal file output .
I wonder if pin 1 on the parport is not responding?
Use halmeter to check the signal 'estop-out'. It should be false during an estop and true otherwise.
09 Dec 2009 12:31 - 09 Dec 2009 12:32 #1272
by BigJohnT
Replied by BigJohnT on topic Re:E-Stop Warning Light - how do i connect???
Chris, I have seen pin 1 not work on a few parallel ports that I have.
Last edit: 09 Dec 2009 12:32 by BigJohnT.
Time to create page: 0.329 seconds
