Remote Control EMC emcrsh Problem
25 Jan 2010 19:32 #1633
by inet
Remote Control EMC emcrsh Problem was created by inet
Hi all,
I'm setting up the telnet communication according to: wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Emcrsh
and everything works.
The only problem I'm having is when I send the command:
set machine on
After that the machine turns on, but I can't send any other command. Not even quit!
Does anyone knows how to fix this problem?
Another thing, is it possible to get the value of the current speed and Stop the program execution from a remote machine?
Cheers,
David
set machine on
Cheers,
David
21 Mar 2010 21:18 - 23 Mar 2010 05:06 #2404
by rescyou
Replied by rescyou on topic Re:Remote Control EMC emcrsh Problem
I use remote desktop sharing to connect remotely to my work machine. I have Ubuntu Karmic at home and run "remmina" as a remote client (much better then the stock ubuntu client)
Link to Remmina install info:
www.ubuntugeek.com/remmina-remote-desktop-client.html
Last edit: 23 Mar 2010 05:06 by rescyou. Reason: Add Link to Remmina
09 Jun 2010 20:06 - 09 Jun 2010 20:34 #3096
by tony
Replied by tony on topic Re:Remote Control EMC emcrsh Problem
Hello there !
Does anyone have a solution for this problem ? I have tried to put EMC in manual or auto mode and emcsrh stills freeze.
[edit]
I am also wondering if I try with emcsh directly instead of using emcrsh, do you think I will have the same behavior ?
[/edit]
Bye
[edit]
[/edit]
Bye
Last edit: 09 Jun 2010 20:34 by tony.
