connect a signal to the AXIS power button?
21 Mar 2012 01:25 #18674
by arch dude
connect a signal to the AXIS power button? was created by arch dude
I just built my first CNC machine, (a Probotix Fireball V90) and I am configuring it, mostly successfully so far. I have all basic functions working.
I want to use the "machine power" button on the AXIS toolbar to control an output pin on the parallel port (which in turn controls an AC relay.) I cannot fine the name of any AXIS pin or signal that is associated with the "machine power" button. There is a status ("enabled".) There is a little text string in the status bar. There is an ijnternal state (c.state) on the python code. but there does not appear to ba a signal that I can attach to an output pin.
Am I missing something? I know that I can create a separate button using pyVCP, but that's sort of dumb considering that you must click the "machine power" button anyway.
Note that this is separate from spindle_enable. I have one of those, too, and it is successfully controllin an output pin, because it has a signal. The "machine on" controls master AC power to the DC supply that drives the stepper drivers, and also AC power to the spindle speed controller. The spindle speec controller then take a spindle_enable and a spindle_PWM.
21 Mar 2012 03:37 #18679
Replied by cmorley on topic Re:connect a signal to the AXIS power button?
If Your INI file loads HALUI then the pin is :
halui.machine.is-on
if not then look for a pin called:
axis.0.amp-enable-out
This is the amp enable for the X axis it will only be true when out of Estop and the machine is on.
There will probably be a signal connected to it already so use that signal
halui.machine.is-on
21 Mar 2012 12:00 #18684
by BigJohnT
Replied by BigJohnT on topic Re:connect a signal to the AXIS power button?
To see the state of a pin open Machine >
Show Hal Configuration
and put the pin in the Watch window. Now toggle the machine power button and see if the pin you selected behaves as you expected it to.
21 Mar 2012 23:24 #18691
by arch dude
Replied by arch dude on topic Re:connect a signal to the AXIS power button?
Thanks, all. I connected axis.0.amp-enable-out to the relay control pin and the button now controls the AC to the mill.
I must say that "amp-enable-out" is not exactly the name I would have chosen, but perhaps there is some history here. I am new to the CNC world.
22 Mar 2012 03:11 #18697
Well in this case the pin you are using is used to enable an amplifier / drive.
It just so happens that it also follows the machine power (which makes sense of course)
When EMC was first made it was made for servos ad servos usually have enable signals.
So that is why it is called what it is called.
- Nondepietjes
26 Feb 2017 14:25 #88631
by Nondepietjes
Replied by Nondepietjes on topic connect a signal to the AXIS power button?
hi,
I have a small question about this topic.
Can somebody tell me how to connect a pin to the machine enable button on axis.
How do i subscribe this in the .hal file?
Thanks in advance
Thanks in advance
28 Feb 2017 13:53 #88727
Replied by andypugh on topic connect a signal to the AXIS power button?
I think that the Axis UI "machine on" (F2) button turns on all the axis.N.amp-enable pins in HAL.
16 Dec 2018 15:32 #122478
by JC10
Hi cmorley, do you a reference in the documentation ? I did not find anything so far.
Replied by JC10 on topic Re:connect a signal to the AXIS power button?
halui.machine.is-on
16 Dec 2018 15:45 #122481
linuxcnc.org/docs/2.7/html/man/man9/motion.9.html
Replied by andypugh on topic Re:connect a signal to the AXIS power button?
linuxcnc.org/docs/2.7/html/man/man1/halui.1.htmlHi cmorley, do you a reference in the documentation ? I did not find anything so far.
16 Dec 2018 16:05 #122483
by JC10
Thank yoh Andy, i am discovering the html part of the manuals.
Time to create page: 0.094 seconds
