Some concepts
10 May 2009 13:13 #226
by hengfo
Some concepts was created by hengfo
hi,
I am a beginner for EMC2. There are some concepts which are not very clearly explained in the document such like TRAJ_period and Servo_period. I want to increase the sampling frequency in my CNC machine, but I don't know how to change these parameters.
Thank you in advance!
10 May 2009 14:25 - 10 May 2009 14:27 #229
by BigJohnT
Replied by BigJohnT on topic Re:Some concepts
This is in the Integrators Manual.
www.linuxcnc.org/docview/html//config_in...%5BEMCMOT%5D-section
You should run a latency test before changing the base period.
Is your config a Stepconf Wizard generated one? If so after running the latency test you can run Stepconf again and change your latency test number there.
www.linuxcnc.org/docview/html//config_st...ub:Basic-Information
Why do you want to change the period settings?
Last edit: 10 May 2009 14:27 by BigJohnT.
10 May 2009 15:14 #230
by hengfo
Replied by hengfo on topic Re:Some concepts
Thank you for your reply.
Because I want to increase sampling frequency. I don't know the meaning of TRAJ_period exactly.
10 May 2009 15:38 #232
by BigJohnT
Other than the information in the first link and in this link that is all I know about traj_period.
www.linuxcnc.org/docview/html//man/man9/axis.9.html
www.linuxcnc.org/docview/html//man/man9/motion.9.html
Time to create page: 0.138 seconds
