Fail to homing (mechanical switch + index pulse)
14 Oct 2013 03:39 #39814
by mayo
Fail to homing (mechanical switch + index pulse) was created by mayo
Hi guys,
I'm newbie in linuxcnc and I have just subscribed to the forum,
I ask your help cause i cannot perform homing correctly (the homing procedure appear to be not correct).
Following I give you details:
For semplicity suppose:
so, practically the following behaviour occur:
What could be?
Where is the mistake?
Does this kind of homing procedure use encoder counts (that I've not connected..)?
Thank you all!!
- using only X axis;
- IO is done with 5i23 MESA board
- axis is moved by a servo (DELTA) using step/dir command
- DELTA driver tell to MESA board when index-pulse has been detected via its IO
- other encoder signal (channels A and B ) are not wired from DELTA to MESA
- halscope correctly detect axis.0.index-enable logic states
- HOME and HOME_OFFSET are both set to zero in INI file
- HOME_USE_INDEX is set to "YES"
- I switch on drive and emc (axis) software
- suppose axis could be anywhere in the working area (just supppose it is in X=XSTART coordinate where XSTART could be any value between axis limits)
- since any absolute encoder is connected axis show me that coordinates are 0,0 and it notify me that no home procedure has been carried out
- i perform homing
- axis X go back looking for mechanical home switch with searchvel velocity
- axis X hits mech switch
- axis X go forward (ascending X coordinates) looking for index pulse with latchvel velocity
- axis X find index pulse
- axis X "should" stop on index pulse since HOME and HOME_OFFSET have been set to zero
- but... instead stopping, axis X continue going to the original position XSTART with home_final_vel velocity
What could be?
Thank you all!!
14 Oct 2013 18:23 #39826
Replied by andypugh on topic Fail to homing (mechanical switch + index pulse)
Did we discuss this on IRC last night, or are you someone else with exactly the same problem?
The issue is that index-homing assumes that the encoder counter is inside LinuxCNC HAL and that it is zeroed when the index is seen and index-enable goes false.
This is not the case here, because you are running a step-dir system and the encoder counter is inside the drive.
Because the index-enable pin of the Mesa encoder counter is an IO pin, it is not trivial to connect it correctly in HAL in the way that it needs to be connected.
I think that the solution is a simple custom HAL component.
component index_toggle "extends the limit switch area to the next index pulse";
pin io bit index-enable "connect to the index-enable of an encoder counter";
pin in bit home-sw-in "connect to the home switch input pin";
pin out bit home-sw-out "connnect to the the motion controller home switch input"
function _;
license "GPL";
static int old_sw = 0;
if (( ! old_sw ) && home_sw_in) index_enable = 1;
home_sw_out = index_enable;
old_sw = home_sw_in;
The following user(s) said Thank You: bkt, CNCCustoms
16 Oct 2013 06:04 #39932
by mayo
Replied by mayo on topic Fail to homing (mechanical switch + index pulse)
Thanks a lot andypugh,
the component works very well!
18 Feb 2017 17:53 #88175
by Feliciano
Replied by Feliciano on topic Fail to homing (mechanical switch + index pulse)
Sorry for my question but what's the procedure to make this component available?
I've never use a custom component in linuxCNC before and using the "The Hal component generator" I was enable even to find the folder "linuxcnc/src", so if you guys that already worked on that could help on this one.
19 Feb 2017 13:54 #88270
Save the code above to a plain text file called index_toggle.comp
Then use the command "sudo halcompile --install index_toggle.comp"
The following user(s) said Thank You: CNCCustoms
25 Oct 2017 14:00 #100794
by Lcvette
Replied by Lcvette on topic Fail to homing (mechanical switch + index pulse)
Andy, this is fantastic assistance!! And will be put to good use!! Thank you for sharing!
Chris
Chris
- CNCCustoms
03 Feb 2018 12:15 #105358
by CNCCustoms
Replied by CNCCustoms on topic Fail to homing (mechanical switch + index pulse)
Thank you SOO much Andy!
My axes repeat to within 1.5 TENTHS now! (0.004mm) And better on Y and Z
So thankful.
Clint
So thankful.
Clint
- CNCCustoms
04 Jun 2018 15:43 #111607
by CNCCustoms
Hi Andy
So after some testing I figured out that the homing was indeed not working. It seems every time the machine is restarted, the home position changes. All depending on where the machine was on startup. I usually left my machine at the home switches when shut down so didn't notice this at first. But it didn't take too long to see something was up. I had work to do so I disabled index homing again.. until now.
The story is as follows when using index homing:
When I startup with my axes in arbitrary places, the machine moves toward the home switches and then homes to where the machine started... REGARDLESS of my homing setting. With the index homing disabled, it homes perfectly no matter what (accuracy is just not great at 0.05 mm)
When I did some scratching, I discovered that at first homing of the machine (Index homing enabled) , a pin called encoder.nn.position-latched is written with the axis current encoder position. The homing begins as usual, switch is tripped, then the index-enable goes on and then off and then the machine moves the axis to the axis encoder position of encoder.nn.position-latched position.
I hope that makes sense? When I searched for what this encoder.nn.position-latched is used for, the documentation says it is not in use.
SO it seems the index-toggle is working... at least I think so?
What could be the problem and what can I try to figure this out?
your help is HUGELY appreciated as always!
Clint
Clint
04 Jun 2018 18:29 #111613
Can you attach your HAL and INI files?
- CNCCustoms
05 Jun 2018 08:38 #111654
by CNCCustoms
Here you go Andy
I upgraded yesterday and then things went pear shaped. Linux crashed for the first time ever. Restarted and all my settings were gone. All the changes I made to the .var file (stores my tool change info)... all gone. Then Linux started to disable for no apparent reason. No message box... very strange.
It was working perfectly before the upgrade. Feel stupid for doing it really.
Well I'm going to start fresh. Im re-installing the image and I will start with a fresh, cleaned up version of my HAL and INI files.
If you can see something in these that may help with the index homing then please do.
Thanks a million!
Clint
Thanks a million!
Clint
Time to create page: 0.384 seconds
