Joint compensation on a 6 axis robot
10 Aug 2016 17:43 #78583
by Cpk_Rbt
Replied by Cpk_Rbt on topic Joint compensation on a 6 axis robot
Thomas,
Thanks for the explanation!
Converting mm to inch is not difficult, as you point out. I just want to make sure that there's nothing squirreled away somewhere that is telling it to expect inches, because then feeding it mm measurements would really mess things up.
Thanks!
Thanks!
10 Aug 2016 18:03 #78584
Replied by andypugh on topic Joint compensation on a 6 axis robot
My expectation would be that inches would work on an inches machine and mm on a metric machine. However it is possible that kinematics is done in Machine Internal Units, which is mm.
Time to create page: 0.105 seconds
