JA homing and teleop
13 Sep 2016 16:51 #80411 by newbynobi
Replied by newbynobi on topic JA homing and teleop
As far as i have experienced, master will not wirk with Ubuntu 10.04!!
Master needs python 2.7 and that is not availiable on Ubuntu 10.04. At least i did not find a solution to that problem!
Norbert
13 Sep 2016 18:03 - 13 Sep 2016 18:55 #80416 by Todd Zuercher
Replied by Todd Zuercher on topic JA homing and teleop
I don't think it is required, at least not when running Master installed from buildbot. I just now installed it from an old Ubuntu 10.04 Linuxcnc live CD on a VM, changed the Ubuntu repos to old-releases, added the Linuxcnc buildbot repos for Master in synaptic, updated the system, and Master 2.8pre was there and ran. (YMMV) Maybe it is required for Gmocapy??? but not for Axis like I just tested.
Last edit: 13 Sep 2016 18:55 by Todd Zuercher.
13 Sep 2016 19:56 #80418 by newbynobi
I only tried building from source, never used buildbot.
It is not requiered for gmoccapy.
Norbert
13 Sep 2016 20:17 #80421 by Todd Zuercher
There are lots (and lots and lots) of dependencies that are required to build from source that you don't need to just run the binaries. (You probably have to have the same ones to compile 2.7 from source.)
Time to create page: 0.105 seconds
