Servo and Mesa pulse encoder/velocity conversion
15 Sep 2016 20:35 #80478
by f1oat
Servo and Mesa pulse encoder/velocity conversion was created by f1oat
Hello,
We are working on a retrofit for a Mori Seiki SL-0 CNC lathe.
The original X/Z axis servo drives are Fanuc analog.
They work in velocity mode with external frequency to voltage conversion embedded in the original CNC controller.
We would like to replace the controller with a Mesa 7i48/6i24 combination.
We plan to use one pulse encoder input to make the frequency to voltage conversion and generate the velocity feedback for the drive. See attached diagram.
Anyone having success with similar setup? Does it make sense?
Do we have to anticipate specific stability problem in the closed loop?
Thanks.
Frederic.
Thanks.
Frederic.
16 Sep 2016 02:52 #80480
Replied by cmorley on topic Servo and Mesa pulse encoder/velocity conversion
one of the developers - Chris Radek - generated the velocity feedback on his Mori junior mill in a similar way.
he said It worked great.
I don't remember the specifics.
If no one else gives you the answer try the mail list or IRC to find Chris.
Chris M
Chris M
Time to create page: 0.266 seconds
