gear hobbing maschine-electronic gearing ?
30 Sep 2016 21:02 #81120
by viski
gear hobbing maschine-electronic gearing ? was created by viski
Hello!
I am thinking to upgrade existing mascine from mehanical gearing to electrical but , would be linux CNC able to do that?
How machine works :
Maschine Diferential is 12 . So , if i want to make 18 teeth i have to calculate gears a, b, c, d or a and d. a is master and d is slave.
soo.. 12/18 is 0,666666666667 . That i will get 18 teeth gear a(master) is 40 teeth and gear d ( slave) is 60 teeth .
If master gear rotate at speed 557 rpm , slave must rotate at speed 371,33333333333333333333333333333 rpm .
Could linux cnc controll at this speed and how ?
Maybe mesa card + analog drive +/-10 vdc or pluto p + hbridge + encoder feedback ?
What would you sugest me?
With best regards,
How machine works :
With best regards,
02 Oct 2016 16:40 #81150
Yes, LinuxCNC can do this very easily. LinuxCNC can do this very easily.
Replied by andypugh on topic gear hobbing maschine-electronic gearing ?
02 Oct 2016 16:44 #81151
This machine of mine is closer to what you are talking about
There is an encoder on the hob spindle and then the work axis is synchronised to that by a servo motor and its encoder. You can do it with any LinuxCNC-supported hardware, it really is a very simple bit of HAL setup.
04 Oct 2016 09:57 #81208
by gaston48
Replied by gaston48 on topic gear hobbing maschine-electronic gearing ?
Hello,
Also possible to machine a helical gear, with an encoder
coupled to the axis X
04 Oct 2016 10:11 #81209
Yes, my hobbing setup for the mill allows me to cut helical gears too.
I have a GladeVCP screen that does basic gear calculations and cuts the gears:
Hello,
11 Oct 2016 20:40 #81563
by opw
Replied by opw on topic gear hobbing maschine-electronic gearing ?
Hi Andy,
Every since seeing your electronic hobbing video I have wanted to setup something similar. As I am exploring Linuxcnc I discovered encoder_ratio component.
On the Linuxcnc wiki you have documented your setup. I was wondering why you did not use the encoder_ratio component for gearing. Is this not suitable for the hobbing setup and realizing an 'electronic gear'?
11 Oct 2016 21:08 #81564
The emcoder_ratio component needs a quadrature encoder on both axes. It counts the A/B pulses of both encoders in software.
My first setup used a Mesa card to count the spindle revs (so HAL never sees the A/B pulses) and a stepper on the work axes (so no slave pulses) and my current setup uses a resolver on the spindle (so no A/B pulses exist anywhere) though it does have an encoder on the slave.
I rather feel that encoder_ratio solves the problem the hard way, and only in a limited set of circumstances.
The following user(s) said Thank You: opw
03 Sep 2020 14:36 #180552
by jefsaro
hello andy,
I made this machine with your help, 10 years ago, it works perfectly in straight cutting, I would like to make the helicoidal, but I do not know how to do it, I attach my configuration.
thanks for the help
have a good day
jf
Replied by jefsaro on topic gear hobbing maschine-electronic gearing ?
hello andy,
thanks for the help
have a good day
jf
03 Sep 2020 16:12 #180558
Helical _ought_ to be fairly easy. But I have not tried it yet.
I know that I claimed to have done so above, but I haven't hooked it up yet.
In theory you just need to add some proportion of the absolute X position to the workpiece angle.
I currently use this HAL component:
To cut a helical you would need to add:
Then in the calculation section:
Note that in this example the helix is defined as an angular lead / mm so that the HAL component does not need to know the gear diameter.
In practice I think that I woild have my GUI calculate that, based on helix angle and the gear parameters (because that _does_ know the pitch diameter.
component hobbing "synchronise a rotary axis to the spindle";
pin in float teeth;
pin in float starts = 1;
pin in float spindle-pos;
pin in float spindle-vel;
pin in float A-pos-cmd;
pin in float gear-pos-fb;
pin out float gear-pos;
pin out float gear-vel;
pin out float A-pos-fb;
author "andypugh";
license "GPL v2+";
function _;
FUNCTION(_){
static double pos_ref;
static double spindle_ref;
static int old_teeth;
if (old_teeth != teeth){
pos_ref = gear_pos_fb;
spindle_ref = spindle_pos;
old_teeth = teeth;
if (teeth != 0) {
gear_pos = pos_ref + 360*starts*(spindle_pos - spindle_ref)/teeth + A_pos_cmd;
gear_vel = spindle_vel / teeth;
A_pos_fb = gear_pos_fb - pos_ref - 360*starts*(spindle_pos - spindle_ref)/teeth;
} else {
gear_pos = pos_ref + A_pos_cmd;
gear_vel = 0;
A_pos_fb = gear_pos_fb - pos_ref;
pin in float y-pos
pin in float lead
gear_pos = pos_ref + 360*starts*(spindle_pos - spindle_ref)/teeth + (lead * y_pos) + A_pos_cmd;
Time to create page: 0.127 seconds
