[Solved]Mesa or config? (pci plug to clean)
12 Oct 2016 16:44 - 13 Oct 2016 07:39 #81580
by bkt
[Solved]Mesa or config? (pci plug to clean) was created by bkt
Hi at all,
yesterday my machine with mesa5i25 and 7i77 work well and the power stay on all night ... these evening I've try to run linuxcnc but appear only error ....
I not make any modification on my config and comp .... but machine not run and dmesg talk about config error .... Mesa card has fault?? or have I made a mistake not want to? honestly I can not understand and the dmesg messages are rather cryptic (would help make sense of error codes that appear ...)
attach dmseg ...
Appreciate any help.
Giorgio
attach dmseg ...
Giorgio
Last edit: 13 Oct 2016 07:39 by bkt.
12 Oct 2016 19:41 #81587
Replied by PCW on topic Mesa or config? yesterday was ok today not run
I dont think this is interface hardware related:
[ 21.206278] milltask[2171]: segfault at 0 ip 080860b3 sp bfaa8ae0 error 4 in milltask[8048000+5d000]
if you google for "milltask segfault linuxcnc" there are a couple of hits that may possibly be related
The following user(s) said Thank You: bkt
13 Oct 2016 07:29 - 13 Oct 2016 07:39 #81597
by bkt
Replied by bkt on topic Mesa or config? yesterday was ok today not run
so I control power ..... 24Vdc was 21V .... so I push Up my dc converter to 25.1V .... 5V is 5.1V .... 220Vac is 231V ac .... but the error is the same .....
I use these machine from 2015 every day all ok ....
Regards
Giorgio
UPDATE
I just now try to clean mesa 5i25 plug ..... now all work ok ....
to be fair I changed the title...
probably the electrical panel has undergone too many vibrations .... PCW you are the best .....
Regards
Giorgio
UPDATE
