How to build ATC Carousel in linuxcnc ?
- Thank you received: 1369
26 Oct 2016 17:06 #82104
Replied by Todd Zuercher on topic How to build ATC Carousel in linuxcnc ?
So you are asking how to configure the actual io? That all depends what kind of physical interface you want to use. (parallel port, Mesa card...)
26 Oct 2016 17:11 #82105
by mhdsi
I presented everything in the first post
I used LPT (DB25, Parallel Port)
Thank you !
Replied by mhdsi on topic How to build ATC Carousel in linuxcnc ?
Thank you !
26 Oct 2016 17:16 #82106
by mhdsi
I see
Thank you very much !
I will try it
Thank you again !
Those are using G-code digital inputs ans ouputs:
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m62-m65
Those are connected to hardware by one of the HAL files in the config. If you ran the demo then you will now have all the files in your ~/linuxcnc/configs folder, but the HAL file for the changer looks like this:
github.com/LinuxCNC/linuxcnc/blob/master...toolchange_index.hal
If you are using a B-axis then you will have more G-code and less HAL to control things.
I see
I will try it
Thank you again !
- eneias_eringer
- Thank you received: 7
26 Oct 2016 17:55 - 26 Oct 2016 17:59 #82108
by eneias_eringer
Yes !!! soon when arrive in my house , but some sub programs titles and comments are in portuguese !!! LOL
Replied by eneias_eringer on topic How to build ATC Carousel in linuxcnc ?
I've seen it many times before
It is my expectation
Can you share your configuration?
Last edit: 26 Oct 2016 17:59 by eneias_eringer.
- eneias_eringer
26 Oct 2016 21:00 #82118
by eneias_eringer
Here is !!
Am sorry but my configs files are a little mess
The following user(s) said Thank You: mhdsi
27 Oct 2016 07:08 #82128
by mhdsi
Thank Eneias Eringer very much!
Your configure make me understand port config (parport.0 is Parallel port, pin-xx is pinout of Parallel port)
Thank again !
Here is !!
Thank again !
10 Jan 2020 05:35 #154529
by rogerxue
Replied by rogerxue on topic How to build ATC Carousel in linuxcnc ?
I'm curious as how to use it without making it an axis?
I'm in the middle of adding a ATC to my machine, I use mesa5i25 + 7i76, the carousel using stepper with step+dir signals with a home switch.
thanks a lot
thanks a lot
10 Jan 2020 11:17 #154538
The "carousel" HAL component can align a carousel to a tool number (using various types of feedback) without the carousel being a G-code controlled axis.
Replied by andypugh on topic How to build ATC Carousel in linuxcnc ?
14 Jan 2020 22:02 #154848
by rogerxue
thanks, are you suggesting I have a secondary controller for carousel, and only expose a feedback of which tool it is at? I can definitely do that, but I think it would be more flexible to control the movement of the carousel directly from linuxcnc. e.g. if I want to move tool to 1, I'll execute gcode like g0 b1. but I also don't want to expose b as an axis in the UI
14 Jan 2020 22:18 - 14 Jan 2020 22:18 #154850
When your G-code says "T6" then the value "10" appears on the hal pin iocontrol.0.tool-prep-pocket:
linuxcnc.org/docs/2.7/html/man/man1/iocontrol.1.html
If you link that HAL pin to the caarousel component and connect a motor of some sort to the output pins of the carousel component then the carousel will move to that pocket number.
You typically need a G-code routine to move the axes in such a way as to perform the sequence, but at least the carousel comp can be used to position the tools.
Start LinuxCNC and then go to the virtual config sim/axis/vismach/vmc-toolchange for a demo config using corousel and a G-code subroutine.
Last edit: 14 Jan 2020 22:18 by andypugh.
Time to create page: 0.099 seconds
