How do I handle a two speed spindle?
17 Nov 2016 15:02 #82900
by Jake
How do I handle a two speed spindle? was created by Jake
I have a two speed spindle on my Hurco,
I need a command from the controller to switch to low speed, then my spindle drive sends a signal back to the controller when its in low.
I would need it to be
if M3<3500 enable low speed which would make the output high to close the low speed contactor, then when input is true it can run in low.
Would this be part of a M code subroutine?
I have searched through the hal manual and main manual trying to find a piece on this and had no luck.
Thanks!
Jake
Thanks!
Jake
17 Nov 2016 16:11 #82907
This should be close, it is what I use on my 2-range lathe:
forum.linuxcnc.org/30-cnc-machines/31224...k-dyna-turn-2l#77191
Replied by andypugh on topic How do I handle a two speed spindle?
Time to create page: 0.097 seconds
