Gentrivkins replaced by Trivkins in Master, any issues?
- guymalpass
12 Dec 2016 21:06 #83982
by guymalpass
I have been using the JA9 branch for a while now successfully but have recently moved to Master since joints_axes was merged. However I am now getting some strange movements which are triggering following errors.
Are there currently any known problems with trajectory planning in master?
Cheers,
Guy
Cheers,
Guy
- Thank you received: 1369
12 Dec 2016 21:36 #83991
Replied by Todd Zuercher on topic Gentrivkins replaced by Trivkins in Master, any issues?
Not that I'm aware of. (but that doesn't mean that you could not have uncovered a bug.)
Give us a better description of your problems.
- guymalpass
12 Dec 2016 21:38 #83992
by guymalpass
Replied by guymalpass on topic Gentrivkins replaced by Trivkins in Master, any issues?
Here is a photo of my live tool plot, the problem occurs when it transitions from gcode line 34 to 35. As can be seen from the plot it doesn't attempt to go round the arc.
- guymalpass
- guymalpass
12 Dec 2016 21:50 #83996
by guymalpass
I have set ARC_BLEND_ENABLE to false and the program is now running fine so maybe there is a bug there somewhere? What information can I provide that may be useful in finding out what's going on here?
- Thank you received: 5924
12 Dec 2016 22:48 #84004
Replied by tommylight on topic Gentrivkins replaced by Trivkins in Master, any issues?
You can also use G64 Pxxx where xxx is the tolerance you want from the actual line. That is a result of high speed and high acceleration, not a bug.
- guymalpass
12 Dec 2016 22:50 #84005
by guymalpass
I do use a G64 term with P and Q tolerances. This error has begun since I moved to master from the JA9 branch
12 Dec 2016 22:56 #84006
I was just reading your reply on the other thread. I had the same problem when i moved from 2.5.4 to 2.7pre, but much worse, but using G64 worked like a charm. Disabling path blending also works, but i do not know if it affects anything else.
Do the same test with half the speed, see if it will follow the given line properly.
- guymalpass
15 Dec 2016 21:53 #84228
by guymalpass
Hi Tommy, looks like you were spot on, I dropped my acceleration and now all is well. I am surprised considering how long I have been running it for without issue. Thanks for your help.
15 Dec 2016 22:32 #84229
You are welcomed, always.
Time to create page: 0.094 seconds
