script for know ngc program loaded??
21 Dec 2016 17:52 - 21 Dec 2016 17:53 #84505
by bkt
script for know ngc program loaded?? was created by bkt
Hello,
I not have any ideas how to bring the name of current ngc program loaded ... I appreciate any link indication to consider how to create this type of script.
giorgio
giorgio
Last edit: 21 Dec 2016 17:53 by bkt.
21 Dec 2016 18:04 #84509
by newbynobi
Replied by newbynobi on topic script for know ngc program loaded??
The following user(s) said Thank You: bkt
22 Dec 2016 01:50 #84531
by bkt
Replied by bkt on topic script for know ngc program loaded??
mhh ... I knows these...
i bring linuxcnc.stat - error channel -ini file parameter ... I can send linuxcnc command ... but nothing to do about the loaded file.ngc name ....
I just use python script for load a different ngc file remotely .... but I have not idea how I can control if the file just loaded is really the next file that Lcnc go to execute ...
Giorgio....
Giorgio....
22 Dec 2016 15:49 #84560
by newbynobi
returns the currently loaded file with path, and that file will be executed if you send a run command.
Just poll for that information.
Norbert
linuxcnc.stat.file
Norbert
10 Feb 2017 15:35 #87771
by bkt
sorry newbynobi ...
Just poll for that information.[\quote] what is means?? is similar to just a little googling?
Regards
Giorgio
11 Feb 2017 10:27 - 11 Feb 2017 10:27 #87807
by newbynobi
Linuxcnc does update the information automatically, but if you want to get the most recent information from within python, you will have to poll thet information in before using it.
I do that in gmoccapy with a timer that updates the informations every 100 ms
in gmoccapy.py look at def _periodic(self)
self.stat.poll()
updates the information, after that
self.stat.file
does return the actual loaded file.
Norbert
self.stat.poll()
self.stat.file
Norbert
Last edit: 11 Feb 2017 10:27 by newbynobi.
Time to create page: 0.134 seconds
