THC experimental
19 Feb 2017 21:16 #88300
Replied by rodw on topic THC experimental
John,
I just had a thought. If you wait after a cut until axis.z.vel-cmd is zero, you will be at the top of the retract height so that would be the safest place to remove the offset. Its up to the user to set that to a safe height above the highest material height on the table.
I used this signal to show up and down LED's on my gmocappy interface.
net signals-is-moving abs.0.in <= axis.z.vel-cmd
net signals-led-movedown abs.0.is-negative => signals.led-move-down
net signals-led-moveup abs.0.is-positive => signals.led-move-up
19 Feb 2017 21:21 #88301
by BigJohnT
Replied by BigJohnT on topic THC experimental
Well if your cutting a very flat clean piece of material there is a good chance the Z axis velocity will be 0 at some point... I kinda thought a safe height and torch off to remove Z offset. Did a git pull and got a merge conflict on the plasma so I'll have to download fresh in the morning during free time (limited bandwidth). I did manage to figure out a few ways to test the component in a sim first.
JT
JT
19 Feb 2017 21:35 #88304
Not if you wait until the torch is off at the end of the cut.The joys of your satellite connection huh!
Have I stopped cutting?
Have I moved up (I am positive)?
Have I stopped moving?
remove offsets
19 Feb 2017 22:53 #88307
by BigJohnT
Yup, no other options to connect to the net any more out here.
JT
JT
Time to create page: 0.191 seconds
