Bug in #<_current_pocket>
02 Mar 2017 14:04 - 02 Mar 2017 14:14 #88875
by jtc
Bug in #<_current_pocket> was created by jtc
Using version 2.7.7 and 2.8.0 pre, and trying to implement a non random toolchanger, mostly using .ngc code, I have the need to fetch the current_pocket so that the tool is left on the same pocket before moving to the next pocket.
In MDI mode, if issuing (debug,#<_current_pocket>), the value does not make sense and does not match the tool table.
It seems that the current_pocket is broken. For example a tool defined by:
Tool 1
Pocket 14
Issuing (debug,#<_current_pocket>), after tool 1 is loaded, does not return 14, and this was the value that I was expecting.
I saw other implementations that use the current_tool to get the pocket slot, but in this case, the user is limited to place the tool number X in pocket number X, and this does not make sense to me (for example forum.linuxcnc.org/30-cnc-machines/29694...-and-a-few-questions)
Tool 1
Pocket 14
Last edit: 02 Mar 2017 14:14 by jtc.
02 Mar 2017 16:38 #88887
Replied by andypugh on topic Bug in #<_current_pocket>
I think that current-pocket actually returns the index of the array element where the code is storing the data for the selected tool number.
It is basically not useful.
02 Mar 2017 16:54 #88888
by jtc
Replied by jtc on topic Bug in #<_current_pocket>
Thank you Andy,
In this case how do I know the pocket of the current tool in spindle, this is, I need to know the place where I should place the current tool, before "browsing" to the next.
02 Mar 2017 23:03 #88904
This was partially fixed in iocontrol some time ago. It looks like they didn't get all of it.
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...89072b107882cae36403
The HAL pin iocontrol.0.tool-prep-pocket shows the "pocket number" from the tool table when you issue a "Tn" command.
This is not elegant, but ought to work.
in the HAL
Then in the G-code:
in the HAL
net tool-pocket iocontrol.0.tool-prep-pocket => motion.analog-in.00
Then in the G-code:
( issue T command just to set HAL pin. )
T #<_current_tool>
M66 E0 L0
#<actual_pocket> = #5399
( now we have the pocket, set the new tool )
T #<_selected_tool>
The following user(s) said Thank You: jtc
03 Mar 2017 20:46 #88953
by jtc
Thank you!
Using this method, and many M66 after, the machine changes tools automatically.
João
João
03 Mar 2017 20:57 #88956
The developers are looking at this bug too, hopefully there will be a fix eventually.
