WHB04B-6 Manual Pulse Coder
12 Jul 2017 14:04 #95731
by smalla
Replied by smalla on topic WHB04B-6 Manual Pulse Coder
There is a very similar MPG named
PHB04B
PHB04B is called programmable.
And the doc say the display is four rows, 11+16+16+16 chars can be used.
If anyone gets the 4th row display something, please explain how to do that.
12 Jul 2017 14:37 #95733
by nebelnoir
Replied by nebelnoir on topic WHB04B-6 Manual Pulse Coder
Okay, I'll try in a week
04 Aug 2017 11:00 #97000
by smalla
It seems You are working too hard, and dont have time
Meanwhile I have completed coding of the driver. There are still work to be done, but for basic movements it seems OK.
Needs some testing though:
please clone this repo and build the whb04b driver
github.com/smalla/linuxcnc
from the src dir run this command to load the necessary config files:
../scripts/linuxcnc ../configs/sim/axis/whb04b/whb04b-6.ini
it would be nice if someone is pointed me in the right direction on how this can be included in the mainline linuxcnc repository. Im not a coder, this is my first job done, so be patient.
The following user(s) said Thank You: Alex.Shamilich
08 Aug 2017 15:07 - 08 Aug 2017 15:07 #97177
Some ways to contribute are described here:
linuxcnc.org/docs/2.7/html/code/contributing-to-linuxcnc.html
You should just be able to submit a pull-request to the LinuxCNC github.
Replied by andypugh on topic WHB04B-6 Manual Pulse Coder
Last edit: 08 Aug 2017 15:07 by andypugh.
22 Mar 2018 21:15 #107737
by ctbenergy
Replied by ctbenergy on topic WHB04B-6 Manual Pulse Coder
There is a machinekit userspace component for the WHB04B-6 from Dipl.-Ing. Raoul Rubien
github.com/rubienr/machinekit
With some changes, this userspace component is also running under LinuxCNC.
If anyone is interested, see github.com/ctbenergy/linuxcnc/tree/2.7-feature-xhc-whb04b-6
I've compiled this userspace component under the 2.7 and master branch, but only tested a few basic functions under LinuxCNC 2.7 so far.
12 Aug 2019 17:36 #141973
by denovich
Replied by denovich on topic WHB04B-6 Manual Pulse Coder
ctbenergy,
Could you share your xhc-whb04b-6.hal file? I have your code compiled under the master branch. Running xhc-whb04b-6 from the command line, I'm seeing all the communication to/from the extension and pendant and it looks good.
I just need help figuring out the pins in that hal file. The code in your repo looks to have pin names that are MachineKit related... stepgen.00.maxvel and stepgen.00.position_scale being particularly problematic. I think steptest.0.maxvel is possibly the linuxcnc equivalent... but I don't know about position_scale. It's not a parameter that I see exposed as a pin.
any help would be greatly appreciated.
12 Aug 2019 18:24 #141977
Replied by PCW on topic WHB04B-6 Manual Pulse Coder
stepgen.NN.maxvel and stepgen.NN.position-scale are normal
LinuxCNC pins, exported by LinuxCNCs (and MachineKits)
stepgen component.
man stepgen
(in a terminal window)
for the stepgen manual page tha list all the stepgen pins and functions
stepgen component.
man stepgen
12 Aug 2019 19:48 #141992
by denovich
I read the docs...
If I try to reference those pins, I get pin not found.
12 Aug 2019 20:15 #141997
You will not have those pins unless your configuration loads the stepgen
component.
To see what pins you have, start LinuxCNC with a working hal file
that at least loads the desired components, and issue this command
(from a terminal window)
halcmd show all > all.txt
Now you have a list of all pins,parameters, and signals
component.
12 Aug 2019 22:56 #142006
by denovich
I have the stepgen component loaded... but no stepgen pins for maxvel and position-scale.
I also loaded the steptest component, which lets me read steptest.0.maxvel, but there is no position-scale equivalent that I see.
See attached output from: halcmd show all
Time to create page: 0.183 seconds
