Punch Press Gcode
05 Jun 2017 14:30 #94094
by AElmasry
Replied by AElmasry on topic Punch Press Gcode
Is this the right place to ask my question? If not someone help please to find the appropriate section of this forum
05 Jun 2017 15:00 #94097
Replied by andypugh on topic Punch Press Gcode
It seems as good a place as any.
But I was away from LinuxCNC machines all weekend.
05 Jun 2017 18:02 #94114
by AElmasry
Thanks andypugh
Waiting for you to get back
05 Jun 2017 20:06 #94122
I think that the trick is to include "modalgroup=1" in the REMAP line. Removing it certainly prevents remapping from working, despite the system stating that it will use the default of 1.
If you want to put the g11.ngc file in the config directory (which is where I think it belongs) then you should use:
You don't currently seem to be using the XY parameters. When you want to, you will need something like this to deal with the fact that X and Y are both optional;
I got in a bit of a tangle trying to see if G11 / g11 made a difference, and ended up with files of both names in both places,
But I figured that you would prefer to have the answer than have me spend an hour or so going through all possibilities.
REMAP = G11 modalgroup=1 argspec=xy ngc=G11
[RS274NGC]
SUBROUTINE_PATH = ./
REMAP = g11 modalgroup=1 argspec=xy ngc=g11
O<g11> sub
(DEBUG, #<x> #<y>)
O100 IF [exists[#<x>]]
O101 IF [exists[#<y>]]
G1 X #<x> Y #<y>
O101 ELSE
G1 X #<x>
O101 ENDIF
O100 ELSEIF [exists[#<y>]]
G1 Y #<y>
O100 ENDIF
M64 P1
M66 P0 L3 Q100
M64 P1
O<g11> endsub
The following user(s) said Thank You: AElmasry
05 Jun 2017 20:52 #94126
by AElmasry
Thanks andypugh
I'll try and get back to you
06 Jun 2017 14:23 - 06 Jun 2017 14:24 #94165
by AElmasry
It show an error:
EOF in file (current executed ngc file)
Seeking o-word: o<g11> from line:0
I added your code before my gcode program and it worked very well.
Is this the right way to remap g11, put it's code inside every ngc file?
Note: it worked only with G11 not g11 in the REMAP =G11
Last edit: 06 Jun 2017 14:24 by AElmasry.
06 Jun 2017 14:38 #94171
No, you should be able to put g11.ngc in the config directory, and then g11 is a new G-code.
06 Jun 2017 15:03 #94174
by AElmasry
Ok, I'll check whats wrong.
I have another problem that sometimes the interpreter execuete next line before reach the desired position
For example
G11 x1500 y500
M64 p0 ( for punching)
Some times i get the punch at x1499 y500
Or x1500 y 499
How can i hold g1 or g11 till get exact position or not exceeding specific error ( 0.1 mm)
For example
G11 x1500 y500
Or x1500 y 499
- Thank you received: 1369
06 Jun 2017 15:55 #94180
Replied by Todd Zuercher on topic Punch Press Gcode
Don't know if this is the answer, but is the machine set for G61.1 mode or the default G64 mode (or G61)?
06 Jun 2017 15:57 #94181
Also if it is a servo, is the dro set to actual or commanded postion?
