Debugging in Pycharm
- terans1085
- Topic Author
13 Oct 2017 07:09 #100316
by terans1085
Debugging in Pycharm was created by terans1085
Hello,
I was wondering if it is possible to use pycharm to debug python code? My linuxcnc is a normal installation from a bootable image, and I cannot seem to find a way to link.
Thanks for help!
Thanks for help!
13 Oct 2017 12:17 #100319
by jtc
Replied by jtc on topic Debugging in Pycharm
- terans1085
- Topic Author
17 Oct 2017 05:01 #100456
by terans1085
Replied by terans1085 on topic Debugging in Pycharm
I cannot seem to find a linuxcnc-dev folder. I have installed linuxcnc as per instructions on linuxcnc.org/docs/html/getting-started/getting-linuxcnc.html , section 7.2 (Ubuntu Precise).
Apologies for my ignorance in this matter!
17 Oct 2017 12:19 #100462
by jtc
on Pycharm python console if you make "import linuxcnc" you get a error?
If so, you have to find where the linuxcnc.so file (I believe its a .so file) is on your system (on /lib folder maybe?). I don't have run in place installations so don't know the correct path...
- terans1085
- Topic Author
19 Oct 2017 05:26 #100535
by terans1085
No it doesn't!
Searching all the drive I managed to find two copies of linuxcnc.so in /usr/lib/tcltk/linuxcnc and /usr/lib/pyshared/python2.7
19 Oct 2017 11:58 #100548
by jtc
if you can import linuxcnc without errors, you should be able to debug your code when linuxcnc is runing.
Time to create page: 0.143 seconds
