Calibration MAX_VELOCITY fixed to 10. BUG?
20 Jul 2010 19:29 - 20 Jul 2010 19:33 #3433
by tklocke
Calibration MAX_VELOCITY fixed to 10. BUG? was created by tklocke
this problem occurs with different versions of EMC2. Actually I'm using EMC2.4.1
The calibration dialog loads every time as the MAX_VELOCITY 10. I can change that and everything is fine, until the dialog is reading the value from the file again. Even if the file doesn't contain 10 as the MAX_VELOCITY, the dialog will load 10.
Cross dependencies?
I had problems with the calibration dialog using EMC2.4.2 (see other post) maybe these problems are linked.
Thanks,
Toby
Cross dependencies?
Thanks,
Toby
Last edit: 20 Jul 2010 19:33 by tklocke.
21 Jul 2010 11:45 #3444
by BigJohnT
Replied by BigJohnT on topic Re:Calibration MAX_VELOCITY fixed to 10. BUG?
