Advice needed: Custom gear switch component
09 Oct 2021 12:08 - 09 Oct 2021 13:00 #222632
by Baderbahn
Advice needed: Custom gear switch component was created by Baderbahn
Hello Guys,
Long time ago a friend gave me a .comp- File which is calculating the gearswitch-movement of the gearbox of my Deckel milling machine.
Yesterday, I installed the component and wired the HAL successfully, but got stuck with the calculation of the choosen gear.
Every time the .comp file just give out the same gear. It seems, that the input-value doesn't get noted.
In Halshow, I checked the Inputs and outputs of the component and saw, that gmoccapy send out the values correctly to the component but the calculation always sends back the same gear (25).
I tried to change a few things, but nothing really works... maybe you are able to find a programming issue ?
I can't getg rid of the feeling, it's just a typo...
Below, you'll find the pinout and calculation section of the .comp file:
Thanks a lot for your help and best regards,
Simon
//Speed Pins
pin in float speed_in "Eingegebene Drehzahl"; //programmed speed
pin out float speed_out "Gewählte Getriebedrehzahl"; //choosen speed
//Output Pins
//gearbox block 1
pin out bit block1_1 "Block1 Bit1";
pin out bit block1_2 "Block1 Bit2";
pin out bit block1_3 "Block1 Bit3";
//gearbox block 2
pin out bit block2_1 "Block2 Bit1";
pin out bit block2_2 "Block2 Bit2";
pin out bit block2_3 "Block2 Bit3";
//gearbox intermediate gear
pin out bit vorgelege_1 "Vorgelege Bit1";
pin out bit vorgelege_2 "Vorgelege Bit2";
pin out bit vorgelege_3 "Vorgelege Bit3";
//motor rpm
pin out bit spindle_fast "Hohe Drehzahl";
pin out bit spindle_slow "Niedrige Drehzahl";
//gear switch signal
pin out bit schalten "Umschaltsignal";
FUNCTION (_) {
// gear ratio of the gearbox
hal_float_t speed;
int drehzahl[22] = {0, 25, 31, 40, 50, 63, 80, 100, 125, 160, 200, 250,
315, 400, 500, 630, 800, 1000, 1250, 1600, 2000, 2500};
int i;
hal_bit_t stufe = 0;
static hal_bit_t stufe_alt;
//set value
speed = speed_in;
if(speed < 0)
speed = -speed;
//calculate gear ratio
for(i = 0; i < 22; i++){
if(drehzahl[i] <= speed) stufe = i; //always choose lower gear ratio
if(speed > 0 && speed <= 25) stufe = 1; //special cause: between 0 and 25 always choose 25
//set all to 0
block1_1 = FALSE;
block1_2 = FALSE;
block1_3 = FALSE;
block2_1 = FALSE;
block2_2 = FALSE;
block2_3 = FALSE;
vorgelege_1 = FALSE;
vorgelege_2 = FALSE;
vorgelege_3 = FALSE;
spindle_fast = false;
spindle_slow = false;
//schalten = false;
//idle
if(speed == 0){
//block1_1 = TRUE;
//block1_2 = TRUE;
//block1_3 = TRUE;
//block2_1 = TRUE;
//block2_2 = TRUE;
//block2_3 = TRUE;
//vorgelege_3 = TRUE;
stufe = stufe_alt; //if spindle ist turned off, change nothing
//intermediate gear
if(stufe > 0 && stufe < 13) vorgelege_2 = TRUE;
if(stufe >= 13) vorgelege_1 = TRUE;
//BLOCK2
if((stufe < 7) || (stufe >= 13 && stufe < 16)) block2_3 = true;
if((stufe >= 7 && stufe < 10) || (stufe >= 16 && stufe < 19)) block2_1 = true;
if((stufe >= 10 && stufe < 13) || (stufe >= 19)) block2_2 = true;
//BLOCK1
i = stufe;
while(i > 3) i = i - 3;
if(i == 1) block1_3 = true;
if(i == 2) block1_1 = true;
if(i == 3) block1_2 = true;
//engine rpm
if(stufe > 0 && stufe < 4) spindle_slow = true;
if(stufe >= 4) spindle_fast = true;
//switch gears if necessary
if(stufe != stufe_alt && speed != 0){
schalten = !schalten;
stufe_alt = stufe;
//send back choosen gear ratio
speed_out = drehzahl[stufe];
ende:
return;
Simon
Last edit: 09 Oct 2021 13:00 by Baderbahn.
09 Oct 2021 13:48 #222639
by db1981
Replied by db1981 on topic Advice needed: Custom gear switch component
is this the whole component? Then it should not compile....
static hal_bit_t stufe_alt; ?? Why declared in the function, so it newer holds the old value.
Why you are using the hal_types in the normal c function? try to use int for stufe and stufe_alt.
09 Oct 2021 15:25 - 09 Oct 2021 15:26 #222652
by Baderbahn
Replied by Baderbahn on topic Advice needed: Custom gear switch component
Hello db1981,
Nearly...
Below you'll finde the complete component (without english description)
As mentioned before, I've just get the file from a friend ("It worked for me") long time ago.
I'm not deeply intocomponent syntax, so I just checked for logical issues...
You mean, I should use
instead of
Nearly...
component gearswitch "Switch gears";
option singleton yes;
//Speed Pins
//Output Pins
function _ fp "gearswitch";
license "GPL";
author "-";
FUNCTION (_) {
hal_float_t speed;
int i;
//Betrag bilden
speed = speed_in;
if(speed < 0)
speed = -speed;
//Stufe berechnen
if(drehzahl[i] <= speed) stufe = i; //immer nächstkleinere Stufe wählen
if(speed > 0 && speed <= 25) stufe = 1; //Sonderfall: zwischen 0 und 25rpm auf 25 schalten
//Alles Nullen
block1_1 = FALSE;
block1_2 = FALSE;
block1_3 = FALSE;
block2_1 = FALSE;
block2_2 = FALSE;
block2_3 = FALSE;
//schalten = false;
//LEERLAUF
if(speed == 0){
//block1_1 = TRUE;
//block1_2 = TRUE;
//block1_3 = TRUE;
//block2_1 = TRUE;
//block2_2 = TRUE;
//block2_3 = TRUE;
stufe = stufe_alt; //Bei Abgeschalteter Spindel nichts verändern
//VORGELEGE
//BLOCK2
//BLOCK1
i = stufe;
//Motorendrehzahl
//Getriebe Schalten wenn nötig
stufe_alt = stufe;
//Eingestellte Drehzahl ausgeben
ende:
return;
int speed;
int stufe_alt;
instead of
hal_float_t speed;
Last edit: 09 Oct 2021 15:26 by Baderbahn.
09 Oct 2021 16:57 #222664
by db1981
this was the error, hal_bit_t is handled intern as bool. So this could never have worked....
I also moved stufe_alt to instance data, so it is hold over the cycle. This is what you normaly want to do with an "old" variable.
I have tested the comp quickly, selecting the gearstages is now working. The rest can't i test, i don't know how your transmission works. but i am missing the spindle twitch (left/right) during gearchange, and the gearchange is not propably locked again spindle turning....
09 Oct 2021 21:26 #222694
by Baderbahn
Hello db1981,
yeah! It works perfectly ! Thank you verry much for your quick response!
"alt" means "old" in german
The mentioned spindle twitch (Deckel just turns the spindle towards one direction, but changes the oriantation of the gear-switch motors from time to time) and also locking gearchange aggainst the running spindle is done by the "old-fashioned" rellay- setup as done in the original wiring diagram.
Tomorrow, I also will upload my HAL-file in this thread, than the other Deckel users have the chance to reuse it
10 Oct 2021 07:57 #222719
by db1981
freut mich...
Ich habe auch ne FP4A 2821 aber noch mit Heidenhain TNC355.....
grüße
grüße
11 Oct 2021 19:13 #222865
by Baderbahn
Leider einiges zu tun, die letzten Tage und keine Zeit gefunden, die Files zu von der Maschine zu ziehen.... kommt noch.
Sadly I had a lot to do during the last days... I'll upload the files within the next few days.
Wußte nicht, daß Du auch Deutscher bist
Die 2821 ist ja eine ganz späte FP4A. Meine ist von 81 - eine der ersten voll-CNC- Deckels - die mit dem "Eierkopf"
I didn't know, you're also german.
Your 2821 is a pretty late machine - mine is one of the first Deckel CNC machines from '81
regards,
Simon
P.S. Ich schreib Dir 'ne PN, wenn's i.O. ist. habe ein, zwei andere Dinge, die ich noch bzgl. LinuxCNC abklären muß. Auf Deutsch ist das schneller erklärt, als auf Englisch.
regards,
Simon
08 Mar 2022 21:43 #236712
by chili023
Replied by chili023 on topic Advice needed: Custom gear switch component
Hi, would it be possible to get the gearbox .comp. I have a FP4 that I am switching to Linux CNC and your skript would push me into the right direction.
Danke und Grüße
Danke und Grüße
11 Mar 2022 14:09 #236935
by chris@cnc
Replied by chris@cnc on topic Advice needed: Custom gear switch component
The comp is already post number 3.
Copy and paste this script in a new file and named to gearswitch.comp
load the linuxcnc-dev packetcompile fileinstall file load new comp in your hal filenow you should see all pins in halshow
sudo apt-get install linuxcnc-dev
halcompile --compile gearswitch.comp
halcompile --install gearswitch.comp
loadrt gearswitch
addf gearschwitch servo-thread
The following user(s) said Thank You: chili023
14 Mar 2022 18:23 #237222
by db1981
Hello,
the functional comp file is attached in post 4.
don't take the content of post 3, this is with errors.
Time to create page: 0.145 seconds
