controlling coolant w/serial port
20 Jul 2009 03:47 #592
by mozmck
Replied by mozmck on topic Re:controlling coolant w/serial port
Glad it worked for you! I'm still learning emc myself. One reason I offered to write it for you is because it didn't look too terribly hard, and because I'm needing to make a much more complex component for a pic-based board using serial communications, and I figured this one would be good to learn some things with.
Glad to be of help!
Glad to be of help!
20 Jul 2009 03:55 #593
Replied by cmorley on topic Re:controlling coolant w/serial port
Would you consider adding your component here:
It would need to be GPL (or compatible)
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?ContributedComponents
Then everyone could benefit.
20 Jul 2009 03:58 #594
by mozmck
Well, since this is custom hardware it probably wouldn't be too useful as is for most people, but it might be good for an example of some sort I guess. Feel free to add it... or I could do it later. Put a GPL statement in it if you do...
20 Jul 2009 15:36 #600
by jerrybaca
Replied by jerrybaca on topic Re:controlling coolant w/serial port
no problem as it might help someone else figure this out seeing it did give me a idea of how the hal works better than the manual did
i dont know if there is a place for hardware projects but i could also upload the project but in the meentime please feel free to put the hal componet up
Time to create page: 0.156 seconds
