Manual tool change + tool lengh touch off
25 Jul 2014 03:38 - 25 Jul 2014 03:46 #49106
by library
Replied by library on topic Manual tool change + tool lengh touch off
First off, orangecat I really appreciate the work you put into this and sharing.
It doesn't seem to behave like I would expect. Here are the steps I'm doing. My tool table is completely blank (no tool sizes, offsets, etc.) just a tool number.
Perhaps I'm misunderstanding something but I would expect tool 3 to return to the two inch, Z=0 location from the first tool. It's almost like the previous tool length offset is not being cleared before saving the Z height.
- Load a drill bit in a collet into the tool holder. Machine thinks it has no tool
- Place a 123 block on top of the vice so there is two inches between the tip of the drill bit and the 123 block. Touch off and call that Z0. Remove the 123 block so if something goes wrong the tool and block won't get damaged.
- From the MDI call M600 (it simply returns, does nothing)
- From MDI call M6 T1. I leave the drill bit in the tool holder since this first measurement is the reference.
- The tip of the drill bit returns to the same spot, verified by sliding the 123 block underneath. TLO is 0
- From the MDI call M6 T2. I swap in a shorter tool, a 1/4" endmill when prompted. It is measured, the tip returns to the same spot. TLO is -.94
- From the MDI call M6 T3. I swap in an even shorter tool, a broken 1/8" endmill stub. It is measured, the tip is driven below the two inch location. TLO is -1.93 the Z location the tool stops at is listed as -.94, the same TLO of the previous tool.
Last edit: 25 Jul 2014 03:46 by library. Reason: tool table info
The following user(s) said Thank You: orangecat
25 Jul 2014 06:43 - 25 Jul 2014 07:03 #49109
by orangecat
Replied by orangecat on topic Manual tool change + tool lengh touch off
Thanks for reporting this problem library. Indeed, the code failed to place the tool back in exactly the same position after the 3rd tool change. I have updated the subroutines in
the earlier post
(to version 1.1) to correct for this problem and tested it for multiple tool changes with significant variations running both shorter and longer.
Last edit: 25 Jul 2014 07:03 by orangecat.
26 Jul 2014 10:03 #49159
by library
Thanks, it works perfectly now. It's very cool to only have to touch off once and then have it automatic from then on.
01 Aug 2014 03:54 #49363
by billykid
Replied by billykid on topic Manual tool change + tool lengh touch off
Thanks Orangecat ! very good !
10 Feb 2016 09:28 #69917
by jut
Replied by jut on topic Manual tool change + tool lengh touch off
Orangecat, excellent work, thank you very much! It work's perfectly on my machine.
06 Jul 2016 01:36 #77066
by hancock
Replied by hancock on topic Manual tool change + tool lengh touch off
Hello,
a huge thanks to Orangecat for the script - I was looking forever for something like this.
I only have the problem that it doesn't behave within a .ngc-file like it does when I use it with only MDI.
Maybe someone has an idea, as I have tried everything and just can't get it right. It either mills in the air or rams into the workpiece...
So this is my procedure:
1. Insert the first tool of the job-file
2. Touch the tool of on top of the workpiece to set Z0
3. Load the job-ngc-file
4. Hit M600
5. Start the job-file
6. Within the job.file I have a M6 command so it ask to insert the tool (already inserted and touched off the workpiece)
7. The job-file M6 command triggers the touch off
8. Milling is correct
9. Next M6 command within the job-file
10. Z-height is wrong - either milling in the air or way below the original Z0
This is a file I used for example
Is there anything wrong with the .ngc-file that needs to be changed (post-processor) or is my order of touching off, etc. wrong?
Your help is truly appreciated!!!
Thanks & regards,
Hancock
4. Hit M600
(VOLLPLATINE)
(T1 D=1. CR=0. - ZMIN=-0.1 - SCHAFTFRSER)
(T17 D=1. CR=0. - ZMIN=-0.2 - SCHAFTFRSER)
N10 G90 G94 G17 G91.1
N15 G21
N20 G53 G0 Z0.
(2D-TASCHE1)
N25 M9
N30 T1 M6
N35 S42000 M3
N40 G54
N45 M9
N55 G0 X2.379 Y11.374
N60 G43 Z15. H1
N65 G0 Z5.
N70 G1 Z2.5 F150.
N75 Z0.
N235 X8.568 Y11.35 Z-0.05 I-0.076 J-0.065
N240 G1 X8.56 Y11.356 Z-0.026
N245 X8.558 Y11.358 Z0.
N250 G0 Z15.
N260 M5
N265 G53 Z0.
(2D-TASCHE2)
N270 M9
N275 M1
N280 T17 M6
N285 S42000 M3
N290 M9
N300 G0 X2.379 Y11.374
Thanks & regards,
Hancock
06 Jul 2016 03:28 #77067
by orangecat
Hi Hancock,
Does the next M6 command, prompt for the new tool, pause, and then do a touch-off?
06 Jul 2016 03:36 - 06 Jul 2016 03:37 #77068
by orangecat
Actually reading this, something isn't right. Perhaps the sequence for M600 is wrong. I always issue M600 in the MDI before loading the file and running it. At the first M6, it should not pause and prompt for a tool change. If it does, that's because M600 did not work as the first M6 after M600 should only do a touch-off without a tool change pause/prompt.
Last edit: 06 Jul 2016 03:37 by orangecat.
06 Jul 2016 07:57 #77071
by hancock
It actually does always pause and prompt for a tool change at the first M6 of the job file. Even if I would have inserted the correct Tx via MDI before (I also issued the M600 before loading the tool).
With every next M6 it also pauses and prompts for the tool change.
Thanks Orangecat for your reply and help so far!!
06 Jul 2016 08:24 #77072
by orangecat
I'd check the installation, to ensure there isn't some problem with the way the M600 command has been configured (maybe the filename is incorrect, or the file is missing...) It's almost certainly the case that the g-code that should be associated with M600 is not being run.
Time to create page: 0.178 seconds
