an analog of linear feed of XY axes
12 Sep 2009 03:40 #818
by Zig
an analog of linear feed of XY axes was created by Zig
Hello knowledgeable Gentlemen,
I have a requirement for a signal which would be representativeo the XY speed of the tool ( not velocity of the two axes) but actual speed of the tip of the tool as it moves across the work platten on my gantry mill.
I can easily plug into step pulse train of the two axes but that will not give me surface speed of the tool.
Is there a way of configuring the hal interface and outputing either a train of pulses whose frequency is the analog of the speed or else a fixed frequency variable duty cycle pulse train whose duty cycle is the analog of surface speed?
12 Sep 2009 04:30 #819
by cradek
Replied by cradek on topic Re:an analog of linear feed of XY axes
The motion.current-vel hal pin gives the velocity of the tool tip but it includes the Z component.
You can generate various kinds of signals from this using pwmgen or stepgen in velocity mode.
12 Sep 2009 04:37 #821
by Zig
Replied by Zig on topic Re:an analog of linear feed of XY axes
Cradek,
Thanks for the comment. I intend to use the Z axis direction flag as a gating signal anyway. Z axis component will be blocked out during Z axis moves.
Time to create page: 0.236 seconds
