configuration of hydrolic controller z axis
25 Sep 2009 08:52 #865
by hayakul
configuration of hydrolic controller z axis was created by hayakul
hi, i am new in emc2 and still reading manuals.
what i am trying to do is controlling the cnc drilling stations with emc2. the machine has x and y axis with stepper driver step/dir config, Z axis has hydrolic cylinder controller. with limit switchs hydrolic valfes activated up and down. i need to stay xy coordinate till the z come back home(up). so where do ihave to write this delay instructions?
what is the easy way to configure this machine?
thanks
thanks
25 Sep 2009 21:31 #867
by acemi
Replied by acemi on topic Re:configuration of hydrolic controller z axis
You can write a custom M function which will start/stop hydrolic valfes and check the limit switches.
See M100-199 from the wiki for more info.
26 Sep 2009 21:43 #874
by BMG
Replied by BMG on topic Re:configuration of hydrolic controller z axis
Will "Exact Path" mode in gcode fix this?
THat way a gcode string such as
G61
G00 Z0.5
G00 X2.0 Y2.0
The third line will not execute until the Z position is reached.
linuxcnc.org/docs/devel/html/gcode_main....#sub:G61,-G61.1,-G64:
Brian
G61
G00 Z0.5
G00 X2.0 Y2.0
Brian
28 Sep 2009 09:17 #879
by hayakul
Replied by hayakul on topic Re:configuration of hydrolic controller z axis
i think M66 solve this problem. both delay and input wait can be used.
"Exact Path" mode in gcode may be altenate.
thanks for all Acemi and Brian
Time to create page: 0.082 seconds
