Machinist Calculator
05 Nov 2012 20:20 - 05 Nov 2012 20:22 #26273
by piasdom
Replied by piasdom on topic Machinist Calculator
Great Job!
the link to your home page(Help/About) doesn't work(not sure if you're worried
about that now) . all else works as stated.
also, one of the other files
(database.pyc), should it also be py ?
Last edit: 05 Nov 2012 20:22 by piasdom.
05 Nov 2012 20:50 #26275
by BigJohnT
Replied by BigJohnT on topic Machinist Calculator
Thanks, I did fix a few things this morning like now you can create a desktop launcher for sfc.
The latest version is 0.3 now.
06 Nov 2012 00:15 #26288
by piasdom
where can i get 0.3 ?
06 Nov 2012 00:41 #26292
by BigJohnT
Just download it again from my web site... I just copy it over.
06 Nov 2012 19:53 #26307
by BigJohnT
You might want V0.5 now after trying it out last night to make some studs for my 300lb anvil stand I added a couple of things...
12 Nov 2012 21:12 #26478
by piasdom
i tried to install windoz 0.2 but got
This application has failed to start because the application configuration is incorrect.
reinstalling the application may fix the problem.
but i'm in win XP. not sure if that matters. Great job on Linux version !
13 Nov 2012 02:32 #26498
by BigJohnT
I on XP as well and installed it but I don't have a clean installation. If you install python and gtk on your windows machine you can run the linux version.
BTW, I'm totally reworking it to separate out metric and inch threads and external an internal to keep is simpler.
02 Sep 2013 03:00 #38380
by billykid
Replied by billykid on topic Machinist Calculator
hi John
I tried, unfortunately only the first page you see treads.
the others are empty.
There are many versions of gtk in the repository, which one should I download exactly?
Mauro
Mauro
02 Sep 2013 03:20 #38381
by BigJohnT
The threads page is the only one I finished... I lost interest in finishing it and now I'm working on a completely new one.
JT
JT
24 Jan 2014 23:40 #43127
by eslavko
Lost interest.... I'm sad...
..but searching for some chip rate calculator that doesn't cost $100
Replied by eslavko on topic Machinist Calculator
JT
Moderators: piasdom
Time to create page: 0.174 seconds
