My new CNC,bring my stone to this community
- laurent_parti
- Thank you received: 10
09 May 2013 00:51 #33798
by laurent_parti
My new CNC,bring my stone to this community was created by laurent_parti
Hi all,
I was able to make a CNC thanks to this forum and Linux CNC. Many guys share informations and I really appreciate it. English is not my mother language and sorry for mistakes but I would also bring my stone and help other guy like me so I decide to film what I do , more easy for me:
You will find different film about the machine driven by linux cnc, and the way I manufacture parts.
Feel free to ask me anyhing, I will try to help
09 May 2013 18:27 - 10 May 2013 03:39 #33819
by charrier
Replied by charrier on topic My new CNC,bring my stone to this community
Je suis de la chatre, 40 km c'est pas loi, donc a cote,et débutant dans la cnc et avec très peu de temps pour m y consacrer mais un peu d aide local s´est des fois plus facile
Slts
Rv
Slts
Rv
Last edit: 10 May 2013 03:39 by charrier.
09 May 2013 18:43 #33821
by BigJohnT
Replied by BigJohnT on topic My new CNC,bring my stone to this community
Very nice machine. Do you have much flex using belts to drive the axes? I use toothed belts on my plasma machine but was concerned about using them for a machine that has side loads...
- laurent_parti
10 May 2013 00:27 - 10 May 2013 01:01 #33849
by laurent_parti
Replied by laurent_parti on topic My new CNC,bring my stone to this community
Hi Charrier,
Feel free to ask any question about my cnc, I will answer if I can
Regards
Regards
Last edit: 10 May 2013 01:01 by laurent_parti.
- laurent_parti
10 May 2013 00:31 - 10 May 2013 01:01 #33851
by laurent_parti
Hi BigJohnT
Regarding timing belt, I do not have concern with. The lash I gage is below 1/100 of mm. But I had a concern at the begining to find the appropriate tension on it. To much tension makes the machine bends and lost its true position.
So I had to make some testings with different tension and I mesure on a back and return movement the loss position until I have 1/100 mm
- laurent_parti
14 May 2013 17:37 #34059
by laurent_parti
Hi all,
Here it is what the machine is able to do in 3/4" 1/8 aluminium thick (21mm):
Thick aluminium milling
Moderators: piasdom
Time to create page: 0.117 seconds
