Cooling fluid recovery
10 Sep 2013 17:29 #38602
by mariusl
Regards
Marius
www.bluearccnc.com
Cooling fluid recovery was created by mariusl
Hi
I am busy with an enclosure for my mill. The question I have is how does one recover the fluid without the chips. I want to make a sump below the machine that will collect the chips. It will have a opening on the side to rake the chips out into a container. So how to recover the fluid from the sump? What does other machines use for this?
Regards
Marius
www.bluearccnc.com
10 Sep 2013 17:53 #38603
by cncbasher
i have an outlet at the side just below what i would call a full sump , and feed that across through another filter to catch the smaller swarf and then feed that back to the main tank
if that makes sense , the idea is the swarf can drop to the bottom of the sump , but the coolant can be pulled off the top or just below with a pump , with a few gauze layers to catch the majority of swarf
Replied by cncbasher on topic Cooling fluid recovery
Hi
10 Sep 2013 17:59 - 10 Sep 2013 18:35 #38604
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Cooling fluid recovery
That makes sense. How do you eject the chips from the sump or do you catch them else where?
Regards
Marius
www.bluearccnc.com
Last edit: 10 Sep 2013 18:35 by mariusl.
10 Sep 2013 19:53 #38613
by cncbasher
the sump has a lift out gauze or expanded grill , or even just a basket made of sheet with some punched out holes so you can lift out and the basket drains , captures 95% of everything
10 Sep 2013 20:00 #38614
by mariusl
Regards
Marius
www.bluearccnc.com
That sounds simple enough. Have you had any experience with the augur system sometimes used?
Regards
Marius
www.bluearccnc.com
10 Sep 2013 20:10 #38615
by cncbasher
iv'e seen auger systems used , but no direct experience , they seemed to work fine , dumping the swarf into large skips ,
but as you had to climb 2 ladders to get to the toolpost , they were on the large side , the lathe was turning ship propshafts so quite a few feet long !
10 Sep 2013 20:50 #38617
by mariusl
Regards
Marius
www.bluearccnc.com
That is very impressive. Luckily not the scale I work on or even want to work on.
I have seen them on medium sized Haas machines but did not pay enough attention to detail to be able to design my own.
Regards
Marius
www.bluearccnc.com
Moderators: piasdom
