Single input for overtravel
20 Nov 2014 16:35 #53228
by Niko
Single input for overtravel was created by Niko
Hello,
I am changing the CNC on a TRAUB milling machine and after looking at the documentation notised that overtravel is indicated by only three switches and they are fed to the coil of a relay . So the CNC only sees overtravel signal but no indication on which axis or max/min .
Is there a net in .hal which is overtravel only and does not specify anything else ? Rewiring will take far too much time .
20 Nov 2014 17:14 - 20 Nov 2014 17:30 #53230
by ArcEye
Replied by ArcEye on topic Single input for overtravel
Hi
It is quite normal to have all limit switches in series feeding one pin.
The usual hal file solution is to create a signal called all-limit which is connected to the signal pin
net all-limit <= parport.0.pin-13-in
Then link all the limit switch pins to it
net all-limit => axis.0.neg-lim-sw-in
net all-limit => axis.0.pos-lim-sw-in
net all-limit => axis.1.neg-lim-sw-in
net all-limit => axis.1.pos-lim-sw-in
net all-limit => axis.2.neg-lim-sw-in
net all-limit => axis.2.pos-lim-sw-in
Physically the switches are chained in series and there is a one wire signal that goes to (in this case) parport.0.pin-13-in
Any break in the signal and the error is activated.
If you have NO contacts instead of NC, you will have to reverse the logic, but I assume if "they feed the coil of a relay" they must be in series not parallel, or it would take all 3 erroring to produce a fault!
Last edit: 20 Nov 2014 17:30 by ArcEye.
The following user(s) said Thank You: Niko
20 Nov 2014 18:45 - 20 Nov 2014 19:09 #53231
by Niko
Replied by Niko on topic Single input for overtravel
Thank you !
Where can I find a list of signals ?
Last edit: 20 Nov 2014 19:09 by Niko.
20 Nov 2014 19:31 #53232
by Rick G
Replied by Rick G on topic Single input for overtravel
20 Nov 2014 20:17 #53235
by ArcEye
The signals can be called anything you like, as long as they are not reserved words or names already in use for pins
I just used the signal name all-limit just because that is the one that stepconf and pncconf use when generating configs with grouped limits, so you may have already seen it.
Think of a signal as a hub.
There is 1 feed only with data from an OUT pin ( like a drive shaft into the hub ), but you can attach many IN pins to it as you like, to share this data ( like spokes on a wheel driven by the hub )
20 Nov 2014 20:50 #53236
by Niko
these lines were not needed .
I am interested in a list of signals that pncconf creates automatically and to simply tap into it .
all-limit was predefined and worked immediately .just because that is the one that stepconf and pncconf use when generating configs
20 Nov 2014 21:43 #53238
by ArcEye
There is no list per se.
The easiest way is to create a dummy config with pncconf, that is something like your machine, but not bothering whether it is exact or not.
Look at the .hal file and you will see it contains a whole plethora of signal names, some of which are used and others may remain unused, depending upon on your config.
These signal names are standard throughout all configs produced with that version of pncconf
Moderators: piasdom
Time to create page: 0.108 seconds
