Spindle orientation, M19 questions.
05 Jan 2015 04:11 #54556
by andradela
Spindle orientation, M19 questions. was created by andradela
Hello folks.
I use in my milling machine a asynchronous motor with a frequency inverter to drive a spindle, now i want to orient it to change tool through a automatic tool changer.
I will use classic ladder to control it. I would like to use a M19 with classic ladder to do that. I would like some samples how to link a M19 with classic ladder?
Thanks in advance.
Thanks in advance.
05 Jan 2015 21:02 #54573
by BigJohnT
Replied by BigJohnT on topic Spindle orientation, M19 questions.
Does your inverter do spindle orientation?
JT
JT
05 Jan 2015 22:25 - 05 Jan 2015 22:28 #54577
by andradela
Replied by andradela on topic Spindle orientation, M19 questions.
Nope, is a siemens frequency inverter, w3.siemens.com/mcms/mc-drives/en/low-vol...s/sinamics-g110.aspx
I will try use the inverter CC brake, with a indutive sensor position.
I'm thinking do this way:
Start M19
Ladder set a multspeed in the inversor through digital output 5Hz.
When the sensor position go true set a ladder output to turn on the brake CC.
Then the motor stops.
I need connect the m19 to the classic ladder to start the process.
Do you believe is possible, it works?
Start M19
Last edit: 05 Jan 2015 22:28 by andradela.
06 Jan 2015 07:40 #54623
by BigJohnT
The orient spindle has several pins that can be connected in your hal file. You will need an encoder on the spindle IIRC.
linuxcnc.org/docs/html/gcode/m-code.html#sec:M19
JT
JT
06 Jan 2015 07:53 #54624
by andradela
Encoder?
But that inverter doesn't works in closed loop. It can't control position.
I just want a signal from m19 conected to classic ladder, the control i will be make by ladder logic.
Maybe motion.spindle-orient.
What you think?
What you think?
06 Jan 2015 21:56 #54660
by BigJohnT
I guess you will have to give it a try and see what you get.
JT
JT
06 Jan 2015 22:54 #54663
It is probably possible to persuade it to. It is just that the loop will be closed in LinuxCNC not in the drive.
Replied by andypugh on topic Spindle orientation, M19 questions.
06 Jan 2015 23:24 #54667
by andradela
You say control position throught emc, encoder and pwm output speed reference?
It works?
It works?
06 Jan 2015 23:46 #54669
It will work, I have done it. How _well_ it works will depend on gear ratio and the nature of the inverter.
I have an example in Youtube, but that was geared 2:1 and with a very old-tech inverter that won't even try below 10Hz, so the results are not very impressive.
It works?
07 Jan 2015 00:00 #54670
by andradela
Nice hear it, send me the youtube link i want watch it.
The gear in my machine is practically 1x1. Did you use ladder logic to control it?
Moderators: piasdom
