Spindle orientation, M19 questions.
07 Jan 2015 00:44 #54672
It is a very bad example, with a very old VFD.
No, just HAL and a PID. This subject has been covered many times before. You should be able to find sample HAL files if you search the forum.
Replied by andypugh on topic Spindle orientation, M19 questions.
Nice hear it, send me the youtube link i want watch it.
The gear in my machine is practically 1x1. Did you use ladder logic to control it?
07 Jan 2015 01:02 #54673
by andradela
Replied by andradela on topic Spindle orientation, M19 questions.
I would like to watch your video.
07 Jan 2015 01:05 #54674
I stress that a more modern VFD will work better:
07 Jan 2015 01:05 #54675
by andradela
I found some subjects about spindle orient but any similar mine.
Asynchronous spindle motor.
07 Jan 2015 01:10 #54676
by andradela
Works fine for me.
07 Jan 2015 01:11 #54677
by andradela
What a kind of encoder did you use?
07 Jan 2015 01:44 #54680
At that point it was a home-made 50-slot wheel.
It will generally work better with a higher-count encoder.
07 Jan 2015 04:11 #54684
by andradela
I found this. What you think?
wiki.linuxcnc.org/cgi-bin/wiki.pl?Closed...pindle_Speed_Control
07 Jan 2015 04:26 #54686
That Wiki page describes spindle speed control, not position control.
Try reading this thread: linuxcnc.org/hardy/dapper/index.php/engl...-211?start=250#51172
Unfortunately it took a lot of iterations to get to a working setup.
07 Jan 2015 05:20 #54694
by andradela
I think using closed loop is too complex for me. I don't know hal config well. I set my machine using pncconf. I'm thinking to do something more simple. Use fixed frequency and brake cc in the inverter.
I'm thinking something like that, tell me what you think.
Set some pon from M19 linked with classic ladder. Maybe that motion.spindle-orient or another.
When M19 is called that pin come true in classic ladder, then i will set an classic ladder output to set a fixed frequency on the inverter throught an digital input. I will use a inductive sensor with a dog to define the right position stop. I will link that sensor to a classic ladder input, and then set another classic ladder out to set a inverter brake CC, ready the spindle is stoped.
In theory it works, what you think? If you think it works, could you please help me?
Moderators: piasdom
