Jogging Pendant & TS3040C-H80 Mill/engraver
14 Jan 2015 13:20 #54992
by CeeCeez
Jogging Pendant & TS3040C-H80 Mill/engraver was created by CeeCeez
Hello all, I am an absolute rookie to LinuxCNC and CNC in general. I have a number of questions so please forgive me if I am not posting correctly or posting in the wrong place.
I'm choosing to go with LinuxCNC over Mach3 on Windows as I have been using Linux for some 14 years as both Desktop and server OS and understand it fairly well. I use SolydK as my every day OS in my laptop and run Debian & Ubuntu servers.
I have LinuxCNC 2.6 successfully installed and running on a half reasonable desktop machine.
So, questions:
1. Can a USB jogging pendant such as this: www.ebay.com.au/itm/2013-CNC-3-Axis-USB-...&hash=item4172125790 be used with LinuxCNC? If no, what can I use? I tried to enable a software jog wheel from here: www.anderswallin.net/2010/08/axis-with-pyvcp-jogwheel/ but did something wrong as it does not appear in the UI. :(
2. Does anyone have experience with the Tonsen TS3040C-H80 4 axis machine on LinuxCNC. I have one of these machines, badged as a Dongdadk but the same thing. I have no English documentation or manuals for the machine and don't know where to start with it.
Thanks in advance.
So, questions:
Thanks in advance.
14 Jan 2015 15:31 #54995
by ArcEye
Replied by ArcEye on topic Jogging Pendant & TS3040C-H80 Mill/engraver
Hi
1) Looks like a XHC clone, if it is then yes
wiki.linuxcnc.org/cgi-bin/wiki.pl?Using_...Wireless_MPG_Pendant
The following user(s) said Thank You: CeeCeez
14 Jan 2015 15:41 - 14 Jan 2015 17:02 #54996
by ArcEye
And 2) This is just one of the ubiquitous 3040 routers under another name
Really you just need to isolate which parport pin goes to what, via the breakout board.
This post and others on that site may assist
EDIT:
or this one even, don't know what happened to the last one
www.cnczone.com/forums/chinese-machines/...cadcam-software.html
EDIT:
Last edit: 14 Jan 2015 17:02 by ArcEye.
15 Jan 2015 08:30 #55019
by CeeCeez
Replied by CeeCeez on topic Jogging Pendant & TS3040C-H80 Mill/engraver
Many Thanks ArcEye, now I have a starting point. I have also found this post:http://linuxcnc.org/index.php/english/forum/9-installing-linuxcnc/24300-machine-parameter-conversion-from-mach3-to-emc2?start=40#50110 Which references similar mill, but I don't see a response with the xml file. I'll jump across to that thread and see if I can restart it.
Moderators: piasdom
Time to create page: 0.126 seconds
