Shape Mill
20 May 2010 20:43 #2935
by djusee
Shape Mill was created by djusee
Hello.
I'm sorry, I do not know English. This can be resolved with EMC the following things? I want to do such a machine Homemade servo controllers are (ELM CHAN) In Solid Works was designed by my friend. How do I import into the program? It is possible to solve this? Thank you
20 May 2010 22:55 #2936
by tenaja
Replied by tenaja on topic Re:Shape Mill
EMC2 can easily do that.
The tricky part is generating the g-code. I would suggest you find a very good CAM program. (One with good tech support available to you--which means you'll have to shop.)
21 May 2010 10:53 #2946
by djusee
Replied by djusee on topic Re:Shape Mill
Thank you. Which CAD program to offer. My friend has designed in Solid Works, but not yet tried to generate g-code. Why tricky?
21 May 2010 13:25 #2954
by tenaja
It's tricky because there are complex curves that are almost impossible to hand-code.
21 May 2010 22:34 #2961
by BigJohnT
Replied by BigJohnT on topic Re:Shape Mill
Nothing is tool complex to hand code just time consuming....
22 May 2010 09:27 #2971
by djusee
Thank you for your help. I'm still a beginner at this. I understand the electronics , my friend is a mechanical, I'll talk to him about this.
Moderators: piasdom
Time to create page: 0.072 seconds
