Servo Purchase Recommendations, Yaskawa?
07 Nov 2021 23:49 #225601
by Michael
Servo Purchase Recommendations, Yaskawa? was created by Michael
Looking to buy good servo motors and drives that integrate well with LinuxCNC. I'm not happy with the servos I have. The requirements I am looking for:
- Run on single phase 240v (US residential)
- Analog control (using 7i77)
- Original motors were SEM/Parvex and were 3000rpm X/Y 3.95Nm (geared 20T:40T), Z 7.5Nm (geared 28T:40T)
- Going on a 1996 Bridgeport TC-22 VMC (6000lbs machine)
- Thank you received: 5946
08 Nov 2021 00:16 #225610
Replied by tommylight on topic Servo Purchase Recommendations, Yaskawa?
The only advice i can dispense is: by them as a motor/drive set, getting them separately means having to tune them first before tuning them in LinuxCNC, at that is quite a challenge seeing as they come with 400 to 900 pages of manuals.
From my limited experience with Yaskawa, they would be my first choice, always.
Just out of curiosity, what drives do you have now ?
That curiosity is not for me in any way shape or form, but i see a lot of issues on this forum with two manufacturers so far, so would be nice to add to their piled up complaints.
08 Nov 2021 00:27 - 08 Nov 2021 00:45 #225612
by Michael
Replied by Michael on topic Servo Purchase Recommendations, Yaskawa?
When you say make sure they are purchased as a set. Isn't it fairly straight forward with the Yaskawa software to tune the drives?
My complaints are well documented in other posts of mine. They are DMM. What are the two you see issues with?
Last edit: 08 Nov 2021 00:45 by Michael.
08 Nov 2021 01:24 #225616
No idea how hard it is to tune them, but from experience with older systems, that is something that takes a lot of time and reading and testing, a lot. I can only assume that is simpler now.
Mine are DMM and ClearPath, the latter since they were selling stepper systems labeled as servo systems, all it took was a single glance at the torque plot.
DMM in general are good for the money, but they seem to have ONLY issues with analogue mode with latency, while in position mode they work properly. Pretty sure ClearPath also put their act together from what i can gather lately.
08 Nov 2021 18:37 #225706
by Michael
The Sigma 5's have software for tuning with an auto feature. Should be a lot easier then the older drives.
I was also looking at Glentek and a couple things stood out. Seem to have a very stream lined form factor for the drives and a wide variety of motor options. They are also a local company in my state which is appealing. Didn't see many posts about anyone using their products however but there is a good amount of used stuff on eBay so they are not an unknown company.
08 Nov 2021 19:28 #225713
by Muzzer
Replied by Muzzer on topic Servo Purchase Recommendations, Yaskawa?
I've bought several sets of Yaskawa servo motor / drive from FA Parts, which is a machine breaker in S Korea. Obviously the older generations of the Sigma drives tend to be cheaper - I think we are now up to Sigma 7. They come in significantly cheaper than new and a similar cost to the likes of new DMM, Lichuan etc.Having said that, Yaskawa are "more professional" products.
www.ebay.co.uk/str/faparts/SERVO-DRIVE-A...?store_cat=456141017
Another source is IndustrialPartsShop although I've found they are better for things like ballscrews, harmonic drives etc. Some are unused but obsolete stock, which are ideal for the likes of us.
www.ebay.co.uk/str/industrialpartsshop
08 Nov 2021 19:43 #225715
by Michael
Thank you for the links. I'm looking for the single phase drives which seem to be unicorns.
I did see a couple places that mentioned some of the 3 phase drives can actually run on single phase but there was no mention of which ones.
09 Nov 2021 20:37 #225871
by Muzzer
For drives under 4kW or so, the inputs generally use passive rectification (as opposed to active PFC), so they are fine on either single phase or three phase as long as the phase to phase voltage is appropriate - they don't know or care either way. The input rectifier bridge has to work slightly harder with single phase, as you are only using 4 diodes instead of 6 but they are typically rated for that application anyway. Besides, unless you are running your drives at full rated power continuously, you won't be pushing them. Looking at the Sigma 5 manual, Yaskawa don't require derating for operation on single phase.
09 Nov 2021 23:05 #225890
by Michael
10 Nov 2021 12:16 #225971
by Muzzer
That's helpful. So you need to check that your model has the Pn00B.2 parameter and it's a 200V Class drive if you really are stuck with 3-ph equipment.
Most of the drives I've used have been 1-ph out of the box (Yaskawa VFD and servo) or will tolerate either 1-ph or 3-ph (Lichuan and DMM Tech servos).
Moderators: piasdom
Time to create page: 0.134 seconds
