Ensuring workpiece is aligned
03 May 2011 19:36 #9568
by zarthcode
Ensuring workpiece is aligned was created by zarthcode
I've made excellent progress in getting my machine up and running. One lingering question, however. What methods does everyone use to ensure that the workpiece that is clamped to the table is "square" with the work offset/coordinate system? Touching-off on X,Y,and Z is fine, but is there another way to detect/ensure that the workpiece isn't rotated and that it's plane is parallel to the milling table?
03 May 2011 19:47 #9569
by BigJohnT
Replied by BigJohnT on topic Re:Ensuring workpiece is aligned
I use a test indicator to indicate my vise fixed jaw to be parallel to the X axis. I then use a dowel in the spindle to set the X location of the material.
03 May 2011 20:38 - 03 May 2011 22:56 #9571
by piasdom
Replied by piasdom on topic Re:Ensuring workpiece is aligned
as long as your fixed jaw is indicated along the X or Y axis(whichever you ues) the part(stock)
will be aligned. i use a dial indicator on the jaw and then i use an edge finder(if available,BigJohnTs' idea
works great also) to home axis to the part.
Last edit: 03 May 2011 22:56 by BigJohnT. Reason: embarresing spello
11 Jun 2011 07:18 #10424
by jCandlish
Replied by jCandlish on topic Re:Ensuring workpiece is aligned
Do you know the Zentrofix gauge? Trivial and accurate.
marwa-tools.ch/Bilder/PDF/Zentrofix-E.pdf
www.majosoft.com/metalworking/html/zero_margins.html
11 Jun 2011 11:33 #10428
by BigJohnT
Pretty neat edge finder. I rarely use one any more. I have one holder with a 1/2 dowel in it and just move the X axis to 0.250" to the left of where I want the left edge to be and Z down. Slide the material up to the dowel and lock it down... done deal.
22 Jun 2011 07:38 #10750
by 1:1
Replied by 1:1 on topic Re:Ensuring workpiece is aligned
We use these at work:
www.haff-schneider.de/index.php?article_id=78&clang=1
A probe DTI crossed with a lever arm DTI = an edge finder ...
And when we break the ceramic probe we use a wiggler:
littlemachineshop.com/products/product_view.php?ProductID=2278
Moderators: piasdom
Time to create page: 0.237 seconds
