Forum Header
XYUV foam configs with stepconf now in master
14 Mar 2015 08:38 #56799
XYUV foam configs with stepconf now in master was created by cmorley
For anyone using the development version (master) of linuxcnc I just pushed changes to stepconf for XYUV foam machines.
I don't have an actual machine to test with but if seems to work in simulation.
If anyone tries it please let me know of success or failures
Chris M
Chris M
The following user(s) said Thank You: bernie_nor
28 Mar 2015 07:09 #57239
by ww_kayak
Replied by ww_kayak on topic XYUV foam configs with stepconf now in master
I've run into a bit of a problem with this.
It works well until I hit the "test this axis" button on U or V.
/usr/bin/stepconf doesn't have a 'u' or 'v' to find the axis number.
I installed the 2.6 Debian ISO, then followed the instruction on buildbot.linuxcnc.org to update to master.
Had it working with hand edited files and the original ISO, but wanted to try your stepconf.
Thanks for the effort.
Tom
Tom
28 Mar 2015 07:25 #57240
Replied by cmorley on topic XYUV foam configs with stepconf now in master
Thanks for testing. does the config work otherwise? I will fix the test soon I hope.
Chris M
Chris M
30 Mar 2015 11:17 #57304
should be fixed now
Chris M
Chris M
31 Mar 2015 21:58 #57347
by ww_kayak
Still has an 'u' axis related error from data not being set correctly.
stepconf:1257 'scale': self.d[axis + "scale"] -> error: expecting number, not Notype ...
The hal file doesn't seem to work, but let me verify that when I get a chance.
01 Apr 2015 07:28 #57357
Thanks for continued testing..looking into it.
Chris M
Chris M
02 Apr 2015 13:50 #57419
I can't match the line number you quoted to the text you showed.
Will try to investigate more...
Chris M
Chris M
02 Apr 2015 18:29 #57427
by ww_kayak
Sorry, I was using the line number as it shows in the src tree
here
Hopefully I'll get to it this weekend. Thanks again.
Tom
Tom
Chris M
- jeffgar2000@gmail.com
04 Jul 2016 22:13 #76994
by jeffgar2000@gmail.com
Replied by jeffgar2000@gmail.com on topic XYUV foam configs with stepconf now in master
Chris how can I enable Foam configs in the latest LinuxCNC? I have been using it for a couple of years with a 3 axis machine but I am not familiar with how to get the development version and enable that.
Jeff
Jeff
05 Jul 2016 12:22 #77027
Replied by andypugh on topic XYUV foam configs with stepconf now in master
This is an old thread, the foam configs are now part of a standard linuxCNC installation. (since version 2.6)
You can see a demo by selecting sim/axis/axis-foam from the config chooser.
Time to create page: 0.127 seconds
