Forum Header
Calibration Problem With A Axis >HELP Please<
07 Dec 2015 12:30 #66552
by Rick G
Replied by Rick G on topic Calibration Problem With A Axis >HELP Please<
Hello,
I have not worked with rotary axis much in the past.
However a couple thoughts.
When working with chains in the past they seem sometimes be be tighter or stretched more in some sections.
That is if you adjust the chain tight and then turn the sprockets to a different location you might find it now loose or very tight.
So the result is may not be actuality linear for that section. Of course the sprockets may also have run out.
A micro steeping drive will attempt to hold a stepper in between steps if command to but as cncbasher pointed out it may not be exact.
At a 5 to 1 ratio this will be more apparent than say a 10 to 1 ratio so the lower the ratio the more any stepper inaccuracy will effect the outcome. A higher ratio may help.
If the error is cumulative a 3,600 deg. move should be off by more than a 360 deg move .
Rick G
Rick G
07 Dec 2015 13:14 #66555
by Sergio
Replied by Sergio on topic Calibration Problem With A Axis >HELP Please<
Hi Rick!
Ok, this would explain the evolution of the error.
So i think i have to change the Gearsystem to beltdrive and hopefully this will solve the problem.
I will report after finishing the change.
In case of divisibility i just should use a gear as big as possible.
So maybe i can put in a 1:6 gear. 1:10 is to big for my System.
Thank You!
Thank You!
13 Jan 2016 15:30 #68319
by Sergio
The problem is solved
I've changed from chain to belt and everything works great.
Thank you all again!
Sergio
Sergio
Time to create page: 0.119 seconds
