Forum Header
ini file
- sandman92k
31 Jan 2016 18:47 #69327
by sandman92k
ini file was created by sandman92k
Can you see all the config settings in a ini file????
- sandman92k
31 Jan 2016 21:11 #69347
by sandman92k
Replied by sandman92k on topic ini file
I was trying to keep from blowing my head off..
I bought a probotix electronic package and was told it was turn key just install and go, that was BS.
so they gave me a cnc file, but they have it locked up so you can not go in and modify the config on it, you can only look at the ini file.
so i was hoping i could see the config file setup in the ini to get a base.
but at this point i am so fustrated and pissed off i am just going to step away, It makes me so mad when people (salespeople tell you one thing and then when they get your money its a different story)
thanks for the help
thanks for the help
01 Feb 2016 02:54 #69355
The following user(s) said Thank You: sandman92k
- sandman92k
01 Feb 2016 03:16 #69357
by sandman92k
I think part of the problem is the electronics package i got did not come with any info and i can not figure out what it is set at, the other problem is the info on linuxcnc is vague and does not go into any details about where and how to find these settings in the config so you can properly set it up.
02 Feb 2016 14:52 #69447
All the configuration is either in the INI file or the HAL file(s).
Start with the INI file, and see which HAL files it loads. Then work through the HAL files and see what information they read from the INI.
You should be able to figure out the parallel port configuration from the HAL file.
But: It might be better just to describe your problems here. We are more likely to be able to help than probotix.
02 Feb 2016 16:48 #69463
by cncbasher
i can't see the file being locked ?
however i can see you installing it , with the wrong properties , which would give that appearance .
try posting the file as an attachment here ,
as Chris & andy say , it wont take us long to figure the problem .
if you have a list of pins needed for the parallel port that would help , along as to which probotix driver you have purchased
keep calm , help is at hand
Time to create page: 0.079 seconds
