Forum Header
Spindle at speed only in reverse
16 Mar 2016 12:06 #71709
by Robban
Spindle at speed only in reverse was created by Robban
Hi
Have a problem that the spindle at speed indicator only works when i run the sindle in reverse.
Any suggestions?
Any suggestions?
16 Mar 2016 15:46 #71720
Replied by andypugh on topic Spindle at speed only in reverse
Without seeing the HAL I can only guess, but I suspect that you need some "abs" functions in the HAL that creates the at-speed signal.
16 Mar 2016 16:06 #71724
by Robban
Replied by Robban on topic Spindle at speed only in reverse
Here is my hal files.
Tried another time with stepconfig with the same result.
16 Mar 2016 16:15 #71727
You could try changing
in your postgui file such that it usesBut that might make it not work in either direction.
If so then it probably means that your spindle encoder is counting backwards, and you need to set the spindle encoder scale to -400
net spindle-cmd-rps-abs => near.0.in1
net spindle-velocity-feedback-rps => near.0.in2
net spindle-at-speed <= near.0.out
setp near.0.scale 1.200000
net spindle-cmd-rps => near.0.in1
16 Mar 2016 16:49 #71731
by Robban
net spindle-cmd-rps => near.0.in1 didnt work but -400 did!
Thanks!
Thanks!
Time to create page: 0.159 seconds
