Forum Header
Need help setting up configuration
26 May 2016 19:37 #75121
by jrupert
Need help setting up configuration was created by jrupert
I have a Stepperonline 3-axis kit with a TB6600 board. Having difficulty in setting up configuration. Does anyone have details of needed settings. I am a first time user of LinuxCNC and I do not have the knowledge for setup.
02 Jun 2016 13:49 #75331
Replied by andypugh on topic Need help setting up configuration
The timings are likely to be the same as the TB6600 chip, which you can probably find online.
However, as a starting point, try 5000nS for each box. Not many drivers need any longer than that, and going shorte ris a very marginal gain.
Time to create page: 0.153 seconds
