Forum Header
Motors run at 1/5th travel
26 Aug 2016 09:10 #79462
by bobhare
Motors run at 1/5th travel was created by bobhare
After many days of toil i have managed to get all three motors doing something sensible. However if i command a traverse of 5 mm they only run for 1mm.
I have played around with multi-stepping in Linux CNC and with the dipper switches on the stepper driver all to no avail. The only way i found of dealing with it was to use a lead screw pitch of 1/5th reality; not, I'm sure, a good solution.
My equipment is:-
DB25 1205 BOB
DM542A Driver
23HS9430 Motors
and I'm running Linux CNC 2.7.6
My settings within STEPCONF are:-
Step Time 7000
Step Space 7000
Direct Hold 5000
Direct Setup 5000
Pin 2 X Step Inverted
Pin 3 X Step Inverted
Motor Steps/rev 200
Micro-stepping 2
Pulley 1:1
Lead Screw pitch 1.25mm/rev (8mm threaded bar)
Max v 25
Max a 750
This computes to 320 steps/mm
The dippers on the DM 542A are set to 1.91A. I've run it at 3A with the same results.
The DM 542A is also set for 2x micro-stepping.
From the DB25 1205 I have connected VDD to PUL+, DIR+ and ENA+.
Help much appreciated.
My equipment is:-
DB25 1205 BOB
DM542A Driver
23HS9430 Motors
Step Time 7000
Step Space 7000
Direct Hold 5000
Direct Setup 5000
Motor Steps/rev 200
Micro-stepping 2
Pulley 1:1
Max v 25
Max a 750
- Thank you received: 5907
26 Aug 2016 13:25 #79481
Replied by tommylight on topic Motors run at 1/5th travel
It looks like you have the scaling not set properly,
[AXIS_X]
MIN_LIMIT = -1000.0
MAX_LIMIT = 1000.0
MAX_VELOCITY = 100
MAX_ACCELERATION = 5000.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.000
MAX_VELOCITY = 100
# NOTE: the step generator module applies its own limits to
# acceleration and velocity. We have discovered that it needs
# to have a little "headroom" over the accel by the trajectory
# planner, otherwise it can fall slightly behind during accel
# and later overshoot as it catches up. In the long term we
# hope to come up with a clean fix for this problem. In the
# meantime, please set STEPGEN_MAXACCEL below to a few percent
# higher than the regular acceleration limit MAX_ACCELERATION
STEPGEN_MAXACCEL = 5200.0
BACKLASH = 0.000
SCALE = 6.6666 <=============
OUTPUT_SCALE = 1.000
MIN_LIMIT = -1000.0
MAX_LIMIT = 1000.0
FERROR = 1.270
MIN_FERROR = 0.254
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 0.0
HOME_LATCH_VEL = 0.0
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = NO
Have a look, you need the drive microsteping, pulley ratio if any, ballsrew pitch, to calculate that.
[AXIS_X]
MIN_LIMIT = -1000.0
MAX_LIMIT = 1000.0
MAX_VELOCITY = 100
[JOINT_0]
TYPE = LINEAR
HOME = 0.000
MAX_VELOCITY = 100
BACKLASH = 0.000
MIN_LIMIT = -1000.0
MAX_LIMIT = 1000.0
FERROR = 1.270
MIN_FERROR = 0.254
HOME_OFFSET = 0.0
HOME_USE_INDEX = NO
The following user(s) said Thank You: bobhare
27 Aug 2016 15:34 #79558
by bobhare
Replied by bobhare on topic Motors run at 1/5th travel
Machines work in mysterious ways. I switched the machine on after my last post and lo and behold it was running at 5 times the travel so i input the correct leadscrew pitch and all is well.
I also found i had to reduce the velocity in the STEPCONF setup to get the motors to function properly.
All is well at the moment but who knows what the future holds!
Time to create page: 0.058 seconds
