Forum Header
Stepconf Wiz?..how much does it actually convert
30 Aug 2016 11:13 #79717
by Spectre
Stepconf Wiz?..how much does it actually convert was created by Spectre
I ran the stepconf wizard on my Mach3 file and it doesnt seem to read all the XML information is this how it is supposed to work?. I had to set all my port pins manually and the units per step and there are a lot of other things it wants to know that I would have thought would have been read from the XML file. Is this correct or do I have a issue?
30 Aug 2016 16:44 #79728
Replied by PCW on topic Stepconf Wiz?..how much does it actually convert
I wasn't aware that stepconf did any conversion at all
AFAIK this has always been done by JT on the forum here with his conversion utility:
forum.linuxcnc.org/forum/9-installing-li...n-from-mach3-to-emc2
30 Aug 2016 21:38 #79756
by Spectre
Replied by Spectre on topic Stepconf Wiz?..how much does it actually convert
I read it that the wizard took the settings from the XML file and setup LCNC to use those ports and settings
30 Aug 2016 22:04 #79758
Yes I guess that's correct now (there's a import mach xml file option)
Sorry I cant help with your issue, I'm not sure what parameters it is intended to import
Time to create page: 0.059 seconds
