Forum Header
Chinese TS 3040 LL Set
03 Oct 2016 21:11 #81195
by Soltan
Chinese TS 3040 LL Set was created by Soltan
Hi!
I bought a Chinese 3040LL TS 4-axis cnc handset, but unfortunately I could not get nowhere data sheet which must be the basic settings.
I would like to arouse life under Linuxcnc. The YouTube video is setup, but I do not understand much English, just to set basic values and values on the menu PnCConf Wizard in the Wizard menu StepConf to the text. To do so, please help.
04 Oct 2016 16:29 #81221
Replied by andypugh on topic Chinese TS 3040 LL Set
Do you have any information about the handset at all? You are not giving us much to go on. How does it connect to the PC?
05 Oct 2016 14:05 #81249
by Soltan
Replied by Soltan on topic Chinese TS 3040 LL Set
Hello!
The only thing that I know that this type I've described, the Dongda Electric Manufacturer's, parallel port connected to the computer. I tried the manufacturer's website to download the timer values for the machine but could not find.
There are up on the youtube video. This is the link to it:
05 Oct 2016 14:15 #81250
I might have become confused by your original message. I thought you were trying to connect a control pendant "handset" whereas I now suspect that you have a 4-axis CNC machine?
Have you tried copying the numbers from the video into Stepconf on your machine?
05 Oct 2016 14:28 #81251
by Soltan
Yes there is a 4-axis machine, unfortunately, fairly badly I speak English.
I will try to give the numbers in the video on my machine but my my my vezérője blue give a picture of him. I do not know how much control in the video is different because there have been some changes in it, I hope you did not change the control itself. Now the youtube hit pretty much where I look at them to try it on my PC settings and will be in touch.
07 Oct 2016 11:12 #81331
by grump
Replied by grump on topic Chinese TS 3040 LL Set
I have the same machine and it works as I would expect after playing with the settings to get the best performance.
I am not saying it's perfect or right but it works very well.
Not sure I understand your problem but if it helps here is my ini file.
06 Nov 2016 17:48 - 06 Nov 2016 17:49 #82512
by Soltan
Hello!
We managed to solve a setting other values.
The file interface.
The file interface.
Last edit: 06 Nov 2016 17:49 by Soltan.
17 Nov 2016 22:48 #82936
by Soltan
Hello!
Can you show pictures full-screen wizard stepconf?
It's been 3 axis setting works only on A axis adjustment is not work for me.
13 Dec 2016 13:24 #84028
by grump
I have a work in progress page on my website here.
Hope it helps.
www.palleteer.uk/projects/cnc-setup/
Hope it helps.
19 Feb 2017 00:59 #88213
by grump
I have updated my Linuxcnc setup page to answer a query I had last night. Thanks for giving me the shove to add to the page. I hope it helps some of you who might be thinking of trying Linuxcnc or buying a Chinese import machine that comes with little or no instructions.
Time to create page: 0.090 seconds
