Forum Header
Need help
- crosscalls
23 Oct 2016 13:14 #81961
by crosscalls
Need help was created by crosscalls
I have an old Shirline cnc mill and lathe. I've tried for a couple years now to install a newer version of linux emc on a Windows computer. Every time I do I can never get any movement out of my stepper motors. I'm having to hook up to the computer with a usb to parallel cord.
What am I missing? Do I need to install some sort of driver?
Please help.
Please help.
23 Oct 2016 14:13 - 23 Oct 2016 14:14 #81964
LinuxCNC runs on Linux. You can't run it under Windows. So I am very unclear on what you mean by "linux emc on a Windows computer"
Also, LinuxCNC needs a real parallel port. (or other hardware). It can not run with a USB to parallel converter as these are for printers and basically act like a USB printer sending data to the parallel port. This means that LinuxCNC does not have the pin-level control of the port that it needs.
It is possible that even though the PC does not have a parallel port on the back panel, that there might be one available as a header on the motherboard for an adaptor like this
Last edit: 23 Oct 2016 14:14 by andypugh.
- eFalegname
- Thank you received: 30
07 Nov 2016 11:10 - 07 Nov 2016 11:11 #82532
by eFalegname
Replied by eFalegname on topic Need help
I just found this video (10-10-2016) on running LINUXCNC on an usb laptop port
"LinuxCNC is running on Ubuntu 16.04 using RT_PREEMPT. Motion hardware consists of an STM32F103 Minimum System Development board"
Last edit: 07 Nov 2016 11:11 by eFalegname.
Time to create page: 0.069 seconds
