Forum Header
Parallel port not working
01 Nov 2016 19:07 #82316
by ax650
Parallel port not working was created by ax650
I've went from 10.04 Lucid to wheezy and linuxcnc 2.7.7. Now my parallel port is not working. I'm using a Sherline cnc mill with Sherline controller. I have checked the bios menu the parallel port is enabled, base i/o address is 378,mode is 378 and interrupt is irq7. Are these the correct setting if not what are the correct settings. I have tried searching but cat seem to find the answer.
Norm
Norm
01 Nov 2016 20:09 #82318
Replied by andypugh on topic Parallel port not working
What did you change? Was this just an update of LinuxCNC on the same OS, or did you reinstall everything from scratch?
01 Nov 2016 20:24 #82320
by ax650
Replied by ax650 on topic Parallel port not working
All new from scratch.
- Thank you received: 1369
01 Nov 2016 20:31 #82321
Replied by Todd Zuercher on topic Parallel port not working
Are you using the motherboards built in parallel port, or an add on card?
Are you using your old config files copied over from old to new?
What version of Linuxcnc were you running before when it was all working?
01 Nov 2016 20:38 #82322
by ax650
Motherboard parallel port Didn't copy old files I was using 10.04 lucid now all new computer and wheezy new install.
Norm
Norm
01 Nov 2016 20:43 #82323
Do you still have the old config files? They should be a good starting point.
01 Nov 2016 20:48 #82324
by ax650
Sorry I don't the old computer motherboard died installed new wheezy on old drive. I did use the drop down menu and selected Sherline 3axis when starting linuxcnc.
01 Nov 2016 21:29 #82325
All that is really likely to be wrong is the base address of the parallel port.
The first thing to try is just "0" and let Linux try to find the first parallel port for you.
01 Nov 2016 21:40 #82326
by ax650
Sorry I'm a total noob is this what you mean netstat -0
Norm
Norm
01 Nov 2016 21:47 #82328
No, in the HAL file when it has "loadrt hal_parport" make the address 0. (or, use 0 as the address in Stepconf, if you are using stepconf)
Time to create page: 0.078 seconds
