Forum Header
Z axis homes in the wrong direction, downwards
- AlbertHall
- Topic Author
23 Jan 2017 12:19 #86472
by AlbertHall
Z axis homes in the wrong direction, downwards was created by AlbertHall
I have set the Z direction so the actual machine movement matches the axis picture.
The home switch is at the top.
I have set the home location at 0
I have set travel from -70 to 0
When I attempt to home the Z axis it moves downwards (away from the home switch).
How do I fix this please?
23 Jan 2017 12:51 #86474
This is a nice easy fix, change the sign of the home search velocity in the INI file.
Replied by andypugh on topic Z axis homes in the wrong direction, downwards
The following user(s) said Thank You: AlbertHall, shipmodeller
- AlbertHall
- Topic Author
23 Jan 2017 13:17 #86477
by AlbertHall
Replied by AlbertHall on topic Z axis homes in the wrong direction, downwards
Not only easy but a fix too!
Thanks, all working now.
- shipmodeller
- Thank you received: 3
03 May 2017 15:12 #92581
by shipmodeller
Replied by shipmodeller on topic Z axis homes in the wrong direction, downwards
I scratched my head on this one for over an hour, figured I did something wrong. So double thanks for the answer. BUT, someone should put this into the guide somewhere. It would seem to me that this is a common thing, especially on the Z Axis.
03 May 2017 15:16 #92582
It is documented here.
linuxcnc.org/docs/2.7/html/config/ini-homing.html
The problem is that if you document every thing in every place you tend towards many identical manual sections...
If you haven't found it, this is the go-to page for all docs:
The following user(s) said Thank You: shipmodeller
Time to create page: 0.079 seconds
