Forum Header
China 6040 Stepconf OK not in Axis
02 Mar 2017 20:49 #88899
by smogol
China 6040 Stepconf OK not in Axis was created by smogol
This is my first post. I write here even if I don't know if it is the right place. Be free to move it to the best entry.
First of all sorry for my poor English.
Here is my concern:
Using stepconf wizard to setup my CNC router from china seems to work.
If I test each axis (XYZA) works quit well. Unfortunately when I switch to the Axis interface, all axes will jog but not the Z one.
I've tried to swap the axis in the configuration and changed the Y step and direction with the Z one. Running Axis I could jog the Y axis who move the Z axes an if I trie to move the Y axis ( using up and down page keys) I got no movement at all.
I am really confused.
I had been using LinuxCNC for the last two years with a DIY wood router with a "red" china controller successfully without problems .
Do you have any clues to solve my problem?
I am using LinuxCNC 2.5 on a Pentium 4 @ 2.4 Ghz / ubuntu 12.04 / 512 MB Ram.
Best regards
Juan-Carlos
Here is my concern:
Best regards
Juan-Carlos
03 Mar 2017 22:01 #88966
by bkt
Replied by bkt on topic China 6040 Stepconf OK not in Axis
ubuntu 10.04 or 12.04?? you can post your ini and hal file?
giorgio
giorgio
04 Mar 2017 11:51 #88985
by smogol
Replied by smogol on topic China 6040 Stepconf OK not in Axis
Hello k-1,
I'm running on 10.04. found my mistake and looked like a fool.
I Stepconf, I set the the Z to go from 0 to -70 instead of -70 to 0 goooo.I would atted fom a wizard that it will tell such a ridiculous setting. This will be a good thing for noobs like me
Tanks anyway for your support
Juan-Carlos
Juan-Carlos
04 Mar 2017 12:35 #88986
by bkt
This would be glad your machine!
Regards
Giorgio
Regards
Giorgio
04 Mar 2017 16:01 #88994
by grump
Replied by grump on topic China 6040 Stepconf OK not in Axis
This might help. www.palleteer.uk/projects/cnc-setup/
Time to create page: 0.093 seconds
