Forum Header
Trying to get motors to spin
- Mechmate999
12 Mar 2017 20:24 #89488
by Mechmate999
Trying to get motors to spin was created by Mechmate999
I received an error when trying to test the X,Y, and Z drives in StepConf. the message reads:
File"usr/lib/pymodules/python 2.7/stepconf/pages.py", line 602, in update_axis_params self.a.update_axis_test()
File "usr/bin/stepconf" line 1451, in update_axis_test halrun.flush()
IO Error:[Errno 32] Broken pipe.
Is this a hardware or a software problem? Any suggestions on where I need to look?
12 Mar 2017 20:57 #89490
Replied by cmorley on topic Trying to get motors to spin
open a terminal and run stepconf from there by entering 'stepconf' (no quotes) then return
try the test again, if it errors it may print some info to the terminal that can help us debug the problem.
also what version of linuxcnc are you using?
Chris M
Chris M
- Mechmate999
12 Mar 2017 23:38 #89494
by Mechmate999
Replied by Mechmate999 on topic Trying to get motors to spin
I closed down the application and then re-ran the StepConf wizard. I'm not sure what I did, but MY MOTORS SPIN! In all 3 axes! This may seem trivial, but I've been trying off and on to get my control box to work for 7 years.
Thanks so much for responding. I'll definietely be back if I have more issues.
This is GREAT!
Mark
This is GREAT!
Mark
13 Mar 2017 03:52 #89499
good luck and continue having fun !
Chris M
Chris M
13 Mar 2017 09:15 #89504
Well look at that! There is hope for me yet !
Says he that started playing with CNC about 2-3 years ago and still does not have a working machine...
Replied by rodw on topic Trying to get motors to spin
This is GREAT!
Mark
Time to create page: 0.111 seconds
