Forum Header
simultaneous homing not working
27 Mar 2017 19:32 #90387
by rogerxue
simultaneous homing not working was created by rogerxue
I have homing/limit on each axis, and set both limt + homing on each of them to a separate pin. so 3 pin for x y and z.
the homing feature works, but it does not home all axis at once, it home them by Z->Y->X
is there some separate setting I need to check to get simultaneous homing to work?
thanks
thanks
- Thank you received: 5918
27 Mar 2017 20:50 #90391
Replied by tommylight on topic simultaneous homing not working
In the ini file there are entries for each joint or axis and at the bottom of each is an entry stating something like :
Home_sequence = 1 or 0 or 2 or....
Set all to 1, that should work, but i would still let Z axis home first then others.
I am a bit rusty on this so you might wana double check this.
28 Mar 2017 08:36 #90421
Definitely works in master branch. For version 2.7 (the current stable release) read this
Homing Sequence
I thought that this was very well written, clear and concise.
Replied by rodw on topic simultaneous homing not working
HOME_SEQUENCE = 1
Homing Sequence
Time to create page: 0.506 seconds
